05-11-2013 #20
The inductance is marginally worse than the CNC4YOU (and Zapp) motors, but you're unlikely to notice much difference assuming they do actually meet the specifications. I measured the inductance of some of the motors I got from CNC4YOU and it was within tolerance.
Definately don't buy those drivers. They're only rated for 50V, so they've used 36V power supplies which is far too low. As you increase the speed required from a stepper motor, the supply voltage must be increased to maintain a high torque output. It's therefore best to run the motors you've chosen (or the CNC4You / Zapp ones) at around 70V. You therefore need to pick drivers which are rated for 80V - e.g. DQ860MA, AM882 and no doubt others which are available from Aliexpress.
Up to you, so long as they're rated for 80V.
The Following User Says Thank You to Jonathan For This Useful Post:
Leadshine website and AM882
By EddyCurrent in forum General ElectronicsReplies: 12Last Post: 24-08-2018, 01:59 AM -
AM882 Alarm Circuit
By Wobblycogs in forum General ElectronicsReplies: 8Last Post: 28-03-2014, 06:06 PM -
AM882 works with Protune - but not with the ZPA5-INT BOB
By badgerman in forum Motor Drivers & ControllersReplies: 19Last Post: 01-09-2013, 09:44 PM -
Problem with AM882 drivers !..... or it could just be me !
By Buba b in forum Motor Drivers & ControllersReplies: 10Last Post: 03-04-2013, 09:28 AM -
AM882,s and Mach3 ......plus hair removal !!!
By Buba b in forum Motor Drivers & ControllersReplies: 3Last Post: 26-10-2012, 05:11 PM
