21-05-2014 #25
Contact me thru PM with your email address and I'll help you with PSU but won't do it over the forum as it can be miss understood by others and potentialy dangerous and damaging if done wrong or misunderstood.! . . . . . . Others may offer over the forum but I'm not prepared to do that.!
Also At the moment looks like you plan to use AM882 for X & Y with DQ860 for Z & A but you have bit of a mixed up setup there mixing digital drives with Analog drives and if Slaving A axis with another(X) to form twin motor axis then you would be much better using same drives on each.! The AM882 would be best for this because they have stall detect and fault signal.
Another thing is the motors.! Which motors are they and do you have a data sheet or model number.? Becasue you quote 425oz rather than Nm I suspect these are the high impedance motors often found cheap on ebay.? If so be aware you will get much lower performance from them for the same amount of Voltage compared to same power motors with lower impedance. This will affect the feeds you'll achieve and lower the amount of torque available higher up the speed curve.!Last edited by JAZZCNC; 21-05-2014 at 07:43 AM.
Leadshine website and AM882
By EddyCurrent in forum General ElectronicsReplies: 12Last Post: 24-08-2018, 01:59 AM -
AM882 Alarm Circuit
By Wobblycogs in forum General ElectronicsReplies: 8Last Post: 28-03-2014, 06:06 PM -
AM882 works with Protune - but not with the ZPA5-INT BOB
By badgerman in forum Motor Drivers & ControllersReplies: 19Last Post: 01-09-2013, 09:44 PM -
Problem with AM882 drivers !..... or it could just be me !
By Buba b in forum Motor Drivers & ControllersReplies: 10Last Post: 03-04-2013, 09:28 AM -
AM882,s and Mach3 ......plus hair removal !!!
By Buba b in forum Motor Drivers & ControllersReplies: 3Last Post: 26-10-2012, 05:11 PM
