    Hi Everybody
    My name is Vagelis and I am from Greece
    I would like your advice and your opinion on the plans below.
    Involving a cnc (1500mm x 1000mm) which
    will runs with Yaskawa servo 400 watt
    Supported profiled rails 20mm, ballscrews X, Y 20mm Z 16mm
    Spindle 2,2 KW water cooled
    The following plans have to do with the table
    I want to make something stiff and adjustable
    The main table is made with 80X80 5mm square tube and the X axis rails will be placed on two ( each side ) I beams. The one I beam (120mm height) will be welded on the table and the above will be adjustable up-down left-right with screws. Before i go on with the plans i think that it will be good to get some opinions from the "experts" as i am amateur at cnc constructions ( sory for my english).
    My main concern is if I beam is suitable for this purpose, or it is better to go with 120X60 5mm tube
    The cutting surface will also be adjustable from the brown L shape angle that can be moved up and down.
    Thanks everybody for your time
ID:	10407   Click image for larger version.
ID:	10408   Click image for larger version.
ID:	10409   Click image for larger version.
ID:	10410   Click image for larger version.
Name:	base front.JPG
ID:	10411   Click image for larger version.
  1. BUILD LOG: New build.Stell frame cnc 1500X1000.Ball screw and gearing calculations
    Last Post: 03-09-2013, 10:37 PM
  2. Adjustable spindle mount?
    By cncJim in forum Marketplace Discussion
    Last Post: 19-06-2013, 08:58 PM
  3. Your Opinion
    Last Post: 22-05-2012, 11:02 AM
  4. Opinion about the structure of the router ...
    By C.AlveSilva in forum Gantry/Router Machines & Building
    Last Post: 01-05-2012, 02:03 PM
  5. WANTED: adjustable tailstock
    By johngoodrich in forum Items Wanted
    Last Post: 29-03-2012, 07:38 PM
