02-05-2014 #16
Roughly in order of priority...(i.e. in order of how much I expect these changes will impact the overall stiffness of the machine:
- The thin plates the linear bearings are mounted on are definitely weak points.
- Keep the Y-ballscrew where it is - it's well positioned. Moving the ballscrew to prevent exposure to swarf is totally the wrong priority - just guard it if necessary.
- The spacing of the bearings on the Z-axis is a bit low - bear in mind the deflection of the linear guide system is proportional to that bearing spacing squared, so every little helps.
- Try to compact the Z-axis to reduce overhang - by making cutouts in the plates you should be able to avoid putting the rails on spacer strips.
- The Z-ballscrew could be made shorter if you want, but it doesn't really matter.
You only need the adjustment slots for mounting the X-axis linear bearings to the gantry at one side - on the other side you could use normal holes and mill a reference edge for the bearings to rest against. That will help slightly with getting things square. It's also a good tactic for the other axes - particularly Z in your design.Last edited by Jonathan; 02-05-2014 at 02:22 PM.
BUILD LOG: New build.Stell frame cnc 1500X1000.Ball screw and gearing calculations
By ba99297 in forum DIY Router Build LogsReplies: 12Last Post: 03-09-2013, 10:37 PM -
Adjustable spindle mount?
By cncJim in forum Marketplace DiscussionReplies: 2Last Post: 19-06-2013, 08:58 PM -
Your Opinion
By PWD in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 22-05-2012, 11:02 AM -
Opinion about the structure of the router ...
By C.AlveSilva in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 01-05-2012, 02:03 PM -
WANTED: adjustable tailstock
By johngoodrich in forum Items WantedReplies: 0Last Post: 29-03-2012, 07:38 PM
