01-11-2013 #31
02-11-2013 #32
Silyavski think Your fooling your self if you think you won't get any resonance, Even machines built from Cast iron get resonance so you have zero chance of getting None with hollow Steel structure.!! . . . . . Yes it will be less than machines built with thinner material or of lesser construction but I guarantee you'll get resonance which shows at the tool when cutting slightly deep in aluminium and definitely in steel.
All the frames shown will be more than enough for DIY use right upto cutting aluminium and massive overkill for most softer materials. But it would be foolish to think just using larger dimension material means you'll get no resonance, no matter how you arrange the joints or welds etc.
Also what's the point of going to all the trouble of building machine that doesn't deflect more than 0.01mm only to use a bed material that will deflect more than an elastic band.??? . . . . Waste of time doing all your doing if your going to use MDF in any part of the bed other than has a spoil board.!!
Even then for any kind of acceptable accuracy you'll have to surface it for every Job.!!
One more point regards adding stiffeners at a later date.?? . . . .WHY . . . when it can be done at the beginning. When ever you weld you have risk of heat distortion so it's not a good idea to be doing this at later date.
Also has most who have built a machine will know and back me up on ounce you have started using the machine you'll never stop to do even simple things let alone major upgrades like welding in stiffeners. . . . . It's known fact if you don't do all the planned things before powering up machine they'll never get done ounce it's working. . .Lol
Ba99274 any of the frames shown including your own designs will be good enough so don't worry you won't go wrong.
02-11-2013 #33
Hi Dean,
First i want to thank you for the help with the machine we talk about that i am building for a friend which wouldn't be possible without your kind help.
I absolutely agree with what you say. I wouldn't want to mislead somebody. I am always speaking in relative terms here, meaning having in mind DIY machines, with best possible price functionality relation, designed to be multifunctional, mainly for wood and for the occasional aluminum job.
That is why i said it will be good if the design is not copied but adjusted to the particular needs. So let me clear some points about the specific design, not to you i mean , cause i kn ow you know it, but to those who read:
-Its meant for wood and plastics. Its meant also for aluminum but only when additional bed is fixed to raise the job
-its meant for deep 3d jobs mainly and Z axis travel -170-200mm
-Its meant for a trunion table to fit for aditional axis for 3d jobs
-its meant if need arises for a removable plasma water bed to be fitted for occasional jobs.
In other words its meant to be all type of machine, so certain sacrifices has to be accepted.
That is exactly why the frame is overbuild and a small spindle is used
I told that to the friend i am building the machine for. In any case, the machine will have 20mm aluminum sheet bed. Over the aluminum 10mm sacrifitial hard phenolic plastic sacrifitial layer. Over it when necessary will be fitted solid 100mm high block of MDF, ply wood or wood, and yes it will be resurfaced each time, i told him so. So basically nothing would flex there. you misunderstood me because of my English, the machine will have 20mm aluminum bed at least,ribbed where necessary, not MDF!
You couldn't be more right. Thats the truth. My smalll cnc has 2 flimsy bearings and i cant find the time even to dismantle and tighten, as i dont stop it at all.
So I believe it would not be necessary at all. Just said it to remind that if a mistake is made with the design, can be fixed later when testing the machine.
So in conclusion/my conclusion i mean
/ , if maximum flexibility and at the same time rigidity for heavy duty aluminum jobs is wanted there are only 3 ways to go:
- Make a specific purpose machine from the beginning like Jonathan did for his friend, with removable bed
or if larger machine is desired:
-make a machine similar to how Dean does them, with removable adjustable bed and bottom frame structure
-make a machine the way i propose and use additional bolted beams to raise the bed or lower it, look at the picture below
In these both cases, at the end the material we use is roughly the same. main point in my design being limited space, so the legs can be removed without compromising the integrity of the design and having to redraw it again.
Of course that design can be further developed with cost savings in mind. For example the middle 2 beams from the lower bed can be made dis-mountable, so they can be used for the upper bed and so on... Look picture below.
Thats what i like about the constructive discussion. makes me think and develop. The idea of the removable 2 beams just made me realize what savings that would be on my next 1250x2500 design
04-11-2013 #34Excuse me Dean but i don’t understand why my cutting table has unsupported edges. At every plan the cutting table beams are welded at the side pieces. Could you please make it more clear?The Bed being a separate unit means the outer frame pieces support the bed material at the edges, the way yours is drawn the edges will be unsupported and could bend or flex under cutting conditions.
Thank for your good words. The truth is that i don’t have time pressure. When i make a step i want to be sure about what i am going to doBa99274 any of the frames shown including your own designs will be good enough so don't worry you won't go wrong.
I am searching over the internet for this construction about a year
The last few months although i thought i knew very much about the subject i find out that mycncuk exist
The answers that i take from the members make me change many of my thoughts
For example i didn’t know that the ball screws have critical speed. My first plan was to connect the motors straight to the ballscrews. Imagine how i would fell when i broke a ballscrew 1500 long running at 3000 rpm. I also thought that I beam is the strongest type of beam..... ( May be for vertical forces )
So every day someone in here give me an advice or correct me, i fell happy about avoiding another mistake
Thanks everybody so much for your help
P.S Sorry for my EnglishLast edited by ba99297; 04-11-2013 at 09:27 PM.
04-11-2013 #35
Since it's already been said that most of the frame designs posted here would be more than adequate, I'll just highlight some general points which may be useful.
I think the frame design silyavski posted in post #30 is well thought out since, among other things, it makes relatively efficient use of material. I'd be inclined to swap the two 100x100mm beams and 80mm spacers with a single piece, perhaps 200x100mm possibly with a higher wall thickness than the rest (or scaled down accordingly if making the rest of the frame from smaller sections). This will obtain a similar stiffness to the original, but reduces the number of pieces to cut by 12 and the number of welded joints is reduced by 20. This would save a lot of time and reduce residual stresses due to there being less welding. Clearly it may not be as cost effective as making the whole frame from the same size material.
Something else to bear in mind is that increasing the size of the steel you use can sometimes make the structure strong enough, with a lot less work than adding lots of small supporting pieces and without necessarily increasing the cost. For example, if you have a piece of 60mm box section with 3mm wall thickness supported at both ends, then in general increasing it to a 80mm beam of the same wall thickness will reduce the deflection to less than 2.4 times the original.
Also, it's better to increase the size of the beam (within reason), than to increase the wall thickness. Continuing with the previous example, the 80mm beam will cost about 33% (assuming it's priced by mass) more than the 60mm beam, so suppose you instead invested that 33% extra in getting a 60mm box section with 3mm thickness to match the weight of the 80mm beam. Both sections will cost about the same, however the 60mm beam is still only just over half as strong as the 80mm, as you've only made it about 33% stronger (not 240% as above). The reason for this is that increasing the wall thickness only gets a linear gain (y=k*x) in strength, compared to a quartic (y=k*x^4) relationship from increasing the size. So in general, you only use a greater wall thickness when you haven't got space to fit a bigger section.
With regards to resonance, MDF is actually a great material to use for the machine bed as it has such good damping properties. I had a lot less problems with resonance on my machine with the MDF bed than I do now with aluminium. If I'm machining an aluminium part for which the finish is more important than the accuracy, I'll sometimes put a piece of 18mm MDF between the part and the aluminium bed as the MDF damps the vibrations, making the 'sweet spot' to get a good finish a bigger spot.Last edited by Jonathan; 04-11-2013 at 11:10 PM.
The Following User Says Thank You to Jonathan For This Useful Post:
05-11-2013 #36
Well ounce again I'm going to have to disagree.!! . . . Not on the strength basis has that's true but on the fact it's better to use larger.? It's only better if the application warrants it and in this case it doesn't. The thicker wall thickness will be more beneficial because it will be less resonant, going Larger on the tube size just increases resonance. For this application then 60mm tube will be more than strong enough so strength isn't a problem so any extra efforts to improve would be better focused on reducing resonance and going thicker on the wall would help here.
Oh dear again I'm disagreeing. . Lol . . I don't have any problems with my aluminium bed and differing finish.? I get the same finish regardless of whether I'm working direct on bed or on any other sacrificial surface. If your bed is affecting finish then reckon you've under built it or your clamping methods are poor.!!
If anything I get more trouble when using MDF than I do when working direct on bed because material can slide if cutting deep, direct on the bed I get much better hold down.
Also Poor finish comes mostly from the tool chattering so if your struggling with finish then I'd be looking at the machine strength and resonance, hence why I put more importance on material Thickness than Size when it comes to steel. (obviously size has to be fit for application)
BA 99297 I'll say it again to be clear "Any of the designs will be strong enough" so if any more focus is needed then I'd direct it to reducing resonance rather than strength.
Oh when I said about unsupported edges I meant you don't have any members to support the Bed base material at the edges. On your designs the edges between table supports won't support the material or any sacrificial material. It may seem a small detail but it can make a difference and for the little extra material/work it's not worth not doing IMO.!Last edited by JAZZCNC; 05-11-2013 at 04:44 PM.
05-11-2013 #37
I don't disagree with you. If you read what I said carefully you'll see that I acknowledged other factors come into it, and was making general comments, not specific assertions for this build.
I agree that if my gantry was stronger it would help reduce chatter, but it's the same gantry with or without the MDF bed and the MDF sheet placed on top of the aluminium bed on my machine definitely makes it easier to get a good finish, so it must be having a damping effect. I'll reiterate for clarity, by 'good finish' I mean 'looks good' - the part itself is clearly not going to be as accurate if it's clamped on MDF.
Also, that's not to say the machine wont get a good finish using just the aluminium bed - it's just more difficult to get the right parameters. Here's a recent example:
05-11-2013 #38Dean or anybody else could you please suggest me a link ( or links) where i can read about resonance dampening basics ( i mean what i should avoid in order to reduce resonance )BA 99297 I'll say it again to be clear "Any of the designs will be strong enough" so if any more focus is needed then I'd direct it to reducing resonance rather than strength.
So far ( tell me if i am wrong ) i realize that low mass and symmetry amplify resonance is that correct?
Now i understand what you mean but i didn’t say that vertically to the table beams i will put t slot aluminium profile ( a friend of mine who makes solar parks on the houses roofs has many meters of them)Oh when I said about unsupported edges I meant you don't have any members to support the Bed base material at the edges. On your designs the edges between table supports won't support the material or any sacrificial material. It may seem a small detail but it can make a difference and for the little extra material/work it's not worth not doing IMO.!Last edited by ba99297; 06-11-2013 at 12:02 AM.
26-12-2013 #39
Hi everybody
These days i have time to go on with my cnc design
For 3d design i use solid works
After the table i will go on with the gantry etc
I would like to know if there is any online library with ready to use elements like bf/bk bearings. profiled rails, ballscrews ballnuts that can be imported in solidwork
If you don't find any maybe this would be an idea ?
There are quite a few models for use with free program, Sketchup
cnc router - 3D Warehouse Search
There is a plugin for Sketchup that allows export to STL
Convert Sketchup SKP files to DXF or STL | guitar-list
I think Solidworks can import STL files
BUILD LOG: New build.Stell frame cnc 1500X1000.Ball screw and gearing calculations
By ba99297 in forum DIY Router Build LogsReplies: 12Last Post: 03-09-2013, 10:37 PM -
Adjustable spindle mount?
By cncJim in forum Marketplace DiscussionReplies: 2Last Post: 19-06-2013, 08:58 PM -
Your Opinion
By PWD in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 22-05-2012, 11:02 AM -
Opinion about the structure of the router ...
By C.AlveSilva in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 01-05-2012, 02:03 PM -
WANTED: adjustable tailstock
By johngoodrich in forum Items WantedReplies: 0Last Post: 29-03-2012, 07:38 PM
