    I know that silyavski likes to have the horizontal beams supported at 2 points like your end view but you loose the triangle in the middle and that is not good.
    If you notice all the three plans carefully you will se that the x rails supported beams have contact with the ground at 3 points not 2. It is possible you get confused between the side and the front view.
    At the side view you can see that every pair of supported rail beams has straight contact in the middle with the groun as my plan have 3 ( red ) foot at every side.
    From left to right i upload Isometric-Top-Front-Side view for every plan
    Also where there are no diagonals or triangular pieces on the cutting table to stop it twisting.
    You are right about the diagonals. I will put them to the plan. Thanks for your advice
  1. BUILD LOG: New build.Stell frame cnc 1500X1000.Ball screw and gearing calculations
    Last Post: 03-09-2013, 10:37 PM
  2. Adjustable spindle mount?
    By cncJim in forum Marketplace Discussion
    Last Post: 19-06-2013, 08:58 PM
  3. Your Opinion
    Last Post: 22-05-2012, 11:02 AM
  4. Opinion about the structure of the router ...
    By C.AlveSilva in forum Gantry/Router Machines & Building
    Last Post: 01-05-2012, 02:03 PM
  5. WANTED: adjustable tailstock
    By johngoodrich in forum Items Wanted
    Last Post: 29-03-2012, 07:38 PM
