02-02-2014 #11
If you see photo number 13 you will see how much space there is. This space isnt enough to match the ball screw between the plate and the 80X80 box beam. So i could even make the gantry a little bit wider or match the ballscrew at the outer side of the red aluminium plate. My first thougth was to put the X axis ballscrews at the same vertical plane as the profiled rails of x axis. In that case the x axis ballscews would cross the back plate of the aluminium construction that i use to attach the steal beams with the profiled rails. I dont know if this is a good idea as in this case i will have the x and y axi ballscrews been corsed very close each other.
BUILD LOG: New build.Stell frame cnc 1500X1000.Ball screw and gearing calculations
By ba99297 in forum DIY Router Build LogsReplies: 12Last Post: 03-09-2013, 10:37 PM -
Adjustable spindle mount?
By cncJim in forum Marketplace DiscussionReplies: 2Last Post: 19-06-2013, 08:58 PM -
Your Opinion
By PWD in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 22-05-2012, 11:02 AM -
Opinion about the structure of the router ...
By C.AlveSilva in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 01-05-2012, 02:03 PM -
WANTED: adjustable tailstock
By johngoodrich in forum Items WantedReplies: 0Last Post: 29-03-2012, 07:38 PM
