You could mount the X motors inside the frame like I did, it stops the machine being wider than it needs to be and leaves room for the cable chain.
03-04-2014 #2
Thanks so far for your opinion and for your advices. I have one main question.
You told me not be afraid of the gantry weight. Not to try to lighten the steel pieces as weight is not such a big problem. I want to ask then why many people try to build the gantries with aluminum that it is lighter than steel and aslo more expensive. Why many people try to make their gantries as light as possible without of course having compromises with stiffness. Finally why nearly every Z axis is made from alluminum and not ftrom steel. In my project i think that with or without the offcuts, the difference in weight will be nearly 20 kgr. If that mass isnt important and have small impact to the performance of the machine, then i have no reason to laser cut the parts the way i show before as the cost for lasercutting is not small.
Thanks again
VagelisLast edited by ba99297; 03-04-2014 at 04:15 PM.
BUILD LOG: New build.Stell frame cnc 1500X1000.Ball screw and gearing calculations
By ba99297 in forum DIY Router Build LogsReplies: 12Last Post: 03-09-2013, 10:37 PM -
Adjustable spindle mount?
By cncJim in forum Marketplace DiscussionReplies: 2Last Post: 19-06-2013, 08:58 PM -
Your Opinion
By PWD in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 22-05-2012, 11:02 AM -
Opinion about the structure of the router ...
By C.AlveSilva in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 01-05-2012, 02:03 PM -
WANTED: adjustable tailstock
By johngoodrich in forum Items WantedReplies: 0Last Post: 29-03-2012, 07:38 PM
