02-05-2014 #17
Jonathan when you say "The thin plates the linear bearings are mounted on " you mean the carriages of X axis of Y axis or both X and Y axis?
The "thin plates" of X axis supposed to be 10mm iron. What thickness is suitable ?
I suppose you mean to increase the distance between the 2 lower and the two upper carriages and that will reduce the Z axis travel
Should i need a second side plate?
VagelisLast edited by ba99297; 02-05-2014 at 11:12 PM.
The creative adult, is the child who survived
BUILD LOG: New build.Stell frame cnc 1500X1000.Ball screw and gearing calculations
By ba99297 in forum DIY Router Build LogsReplies: 12Last Post: 03-09-2013, 10:37 PM -
Adjustable spindle mount?
By cncJim in forum Marketplace DiscussionReplies: 2Last Post: 19-06-2013, 08:58 PM -
Your Opinion
By PWD in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 22-05-2012, 11:02 AM -
Opinion about the structure of the router ...
By C.AlveSilva in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 01-05-2012, 02:03 PM -
WANTED: adjustable tailstock
By johngoodrich in forum Items WantedReplies: 0Last Post: 29-03-2012, 07:38 PM
