    Looking good, I think the legs are okay as they are. Make sure you paint the frame before doing the epoxy, it's a lot easier, but leave just the top surface of the upper rails bare metal so the epoxy sticks good.
    Starts to look very impressive. Nice job. I envy you for your big and nice looking workshop.
    -In my opinion you don't need to adjust the table by bolts. The machine needs to be sturdy at earth level. I plan to buy for mine 6 hockey plucks. That's what my friend did and works like a charm. Not needed, but he is a maniac.
    -if you follow what Eddy said and paint it, may be don't paint also where the ball screw end supports will be. When the gantry is mounted, then fix the ball screw, then go to one end and then tack solder the fixture for the end support, then go at the other end and repeat. Then remove the ball screw and then solder it carefully there. So when all is ready in the same manner you rectify the ball screws. Cause if you solder now, later may be there would be need to re drill the holes and waste a lot of effort. That's my way of course.
    Thanks both for your valuable advices.
    Syliavski when you say NOT to adjust the table by bolts, what if there is any imperfection 1cm at the floor ? The hockey plucks that you suggest will be welded at the frame. What material are made of these plucks?
    When you are talking about the balscrew fixture end support, you are talking about X axis? If you see my plans i am going to attach the fixture to the frame with bolt so it will be adjustable.
    As for my work shop thanks for your comments. There is my paradise. Music, creation, and no one to bother me.
    The creative adult, is the child who survived
    Quote Originally Posted by ba99297 View Post
    Nice, where I am it's mostly pissing down with rain.
  5. The Following User Says Thank You to EddyCurrent For This Useful Post:
  6. #5
    I bought M25 or so bolts for the machine, soldered the nuts to the legs, thinking that will hold. When the machine was ready i left it on the nuts only and they lay on the hockey pucks. cause i did not find M25 bolts sturdy enough. On your machine M25 6cm bolt on the legs will shake like a plastic, once that heavy gantry starts accelerating.
    The pucks are made from hard PU rubber. make sure they are the solid ones, not refilled with something.
    You call 1cm imperfection , i have to deal with 6-7 cm inclination in my garage and i plan to level it with cement. Thats what is best to do, to level the floor under the machine. If i had to deal with 1cm, i would simply stick 10mm steel plate below the leg.
    Translate for you design:
    I meant these pieces in blue Not to be welded until the gantry is ready and mounted and rectified in all directions:
Name:	AutoSave_cnc 100x100x3 profile x400y1000z200.jpg
    Then bolt these 2 together with a piece of paper between them/that for the later paint thickness
Name:	AutoSave_cnc 100x100x3 profile x400y1000z200 2.jpg
    Then bolt all that is in blue together as it would be at the end, trying all bolts to be in the center of the holes. the bolts must not be tightened very much
Name:	AutoSave_cnc 100x100x3 profile x400y1000z200 3.jpg
    Now move to one end the gantry and spot weld with 5- 6 spots 1 of the pieces in blue from the first picture. Rotate by hand the screw and move to other end of machine. Now you spot weld the other fixture.
    then dismount all in blue, ballscrews , etc. Then weld well the 2 fixtures. No everything is in parallel/guide rails and ball screws/ and perpendicular/ball screw supports.
    When painted and ready, mount them the same way. So the only necessary adjustment will me made by the play of the bolts that hold the ball screw end supports to the fixtures. Tighten them when gantry is at that end.
    In other words, now all 2 rails and 2 ballscrews are exactly parallel and have exactly same travel. Doesn't matter if one is up or down, otherwise using other method that also should be taken care of.
  7. #6
    PS. Somebody has to hold the screw not to bend by its weight and the weight of the fixture
  8. #7
    Silyavski thank so much for your time and your help
    Also thanks for your plans and your colored designs
    I will make the legs ( they wont be 6cm long) i will make them as sort as possible
    I will use them to perfectly level the machine while apply the epoxy at x axis, and if the floor is leveled when i pu the machine at its final position, i may only use shims
    Thanks again
    Vagelis
    Ps:My ballcrew end support fixtures wont be welded but bolted at the frame so it will be possible to make small adjustments
  1. BUILD LOG: New build.Stell frame cnc 1500X1000.Ball screw and gearing calculations
    Last Post: 03-09-2013, 10:37 PM
  2. Adjustable spindle mount?
    By cncJim in forum Marketplace Discussion
    Last Post: 19-06-2013, 08:58 PM
  3. Your Opinion
    Last Post: 22-05-2012, 11:02 AM
  4. Opinion about the structure of the router ...
    By C.AlveSilva in forum Gantry/Router Machines & Building
    Last Post: 01-05-2012, 02:03 PM
  5. WANTED: adjustable tailstock
    By johngoodrich in forum Items Wanted
    Last Post: 29-03-2012, 07:38 PM
