    Silyavski thank so much for your time and your help
    Also thanks for your plans and your colored designs
    I will make the legs ( they wont be 6cm long) i will make them as sort as possible
    I will use them to perfectly level the machine while apply the epoxy at x axis, and if the floor is leveled when i pu the machine at its final position, i may only use shims
    Thanks again
    Vagelis
    Ps:My ballcrew end support fixtures wont be welded but bolted at the frame so it will be possible to make small adjustments
    The creative adult, is the child who survived
    Hi everybody
    Here is my last week progress
    Firstly i get the bolts and the steel pieces laser cutted last Friday
ID:	13035Click image for larger version.
    In order to save money i didnt laser cut the holes ( wherever needed ) except the straight slots. I just ask to point the center of the holes
    So i use these centers and then i drill the holes
ID:	13037Click image for larger version.
ID:	13038Click image for larger version.
    At the following photo you can see two pieces that will be bolted together. The upper piece will be welded with the gantry tubes and then it will be bolted with the lower piece. The holes of the two pieces should be excactly coeficient so i drill the upper piece an the i put the one piece over the other to mark the ceter of the holes
ID:	13040Click image for larger version.
    After pointing the centers i had to drill the holes. That took me A LOT OF TIME. Even more time i need for the tapping
ID:	13042Click image for larger version.
ID:	13043Click image for larger version.
    Today i start the adjustable foot construction. Syliavski suggest me not to put that foots. Even if i use them or not they are very usefull to level the table as perfect as possible for the epoxy method. You will see each foot has 4 holes. The one at the center is for the bolt the other two ( the smaller ones ) are to bolt a softer material at the side of the foot that touch the ground. The fourth hole is for bolting the foot at the floor
ID:	13045Click image for larger version.
ID:	13046Click image for larger version.
ID:	13047Click image for larger version.
ID:	13048Click image for larger version.
    Then i lift the table with the winch and put the foots
ID:	13050Click image for larger version.
    After that i go on with the tapping. Too much time but the result was more than good
ID:	13052Click image for larger version.
ID:	13053Click image for larger version.
ID:	13054Click image for larger version.
    After i bolt the side parts i start to work with the gantry. I put the two side braces on the table and then i attach the vertical 10m plate.
ID:	13056Click image for larger version.
    If you can see the stell plate has two projections ( left and right ) that will "sit" at the side braces so that the distance will be driven by these slots. It is something like a tagram.
    Then i use long bolts to "tune" the gantry
ID:	13059Click image for larger version.
ID:	13060Click image for larger version.
    At the follwing video you can see how everyhing joined nice
    At the above photos you cant see the gantry tubes, as i put them later. But you can see them at the follwing video where i make a level test
    This is my progress so far. Tomorrow i will bolt the front steel plate at the tubes and weld the tubes with the internal side plates
    Thanks for your time
    I will be glad to here your comments
    Vagelis
    The laser cut parts look great, I like how the holes have been marked with both a centre and an outline of the hole. This is good engineering practice and I don't know if you already know this but if the drill moves off centre this is how to bring it back into line;
    If the outline of the hole had not been marked you would not know if the drill had moved off centre.
    https://www.youtube.com/watch?v=ESWzx3YBo3g
    Nah good engineering practice is to do it right first time and use a proper spot drill not some poxy pin prick mark.!!
    Looking Good Vagelis don't drop it on your toes mate. . .Lol . . . . . .Drilling & Tapping 100's of holes in 10mm steel is good for building character and stamina needed to setup and run CNC machine. .
    That is correct but it's not what I said.
    I said, ". . . the holes have been marked with both a centre and an outline of the hole. This is good engineering practice . . ."
    I know this because I have served a proper engineering apprenticeship when things were done right.
    One small problem
    I phone the supplyer of west system resigns here in Greece and he told me that for 105 resign he only has the 206 hardener and not the 209 ( that is recomended by the members here in my cncuk). Do you think that i can do my Job with the 206 hardener and not the 209. The temperature here in Greece is 32-35 and nearly 25-30 at my worklace.
    Quote Originally Posted by ba99297 View Post
    One small problem
    I have used the Wests System and spoken to them a couple of times. I think you really need the 209 as it has a very slow cure and that is what you need for the resin to level out. I purchased mine here : http://www.ecfibreglasssupplies.co.uk/ not many suppliers appear to stock it but can order it for you. ..Clive
  1. BUILD LOG: New build.Stell frame cnc 1500X1000.Ball screw and gearing calculations
    Last Post: 03-09-2013, 10:37 PM
  2. Adjustable spindle mount?
    By cncJim in forum Marketplace Discussion
    Last Post: 19-06-2013, 08:58 PM
  3. Your Opinion
    Last Post: 22-05-2012, 11:02 AM
  4. Opinion about the structure of the router ...
    By C.AlveSilva in forum Gantry/Router Machines & Building
    Last Post: 01-05-2012, 02:03 PM
  5. WANTED: adjustable tailstock
    By johngoodrich in forum Items Wanted
    Last Post: 29-03-2012, 07:38 PM
