The laser cut parts look great, I like how the holes have been marked with both a centre and an outline of the hole. This is good engineering practice and I don't know if you already know this but if the drill moves off centre this is how to bring it back into line;
If the outline of the hole had not been marked you would not know if the drill had moved off centre.
https://www.youtube.com/watch?v=ESWzx3YBo3gLast edited by EddyCurrent; 12-08-2014 at 10:20 PM.
12-08-2014 #2
Nah good engineering practice is to do it right first time and use a proper spot drill not some poxy pin prick mark.!!
Looking Good Vagelis don't drop it on your toes mate. . .Lol . . . . . .Drilling & Tapping 100's of holes in 10mm steel is good for building character and stamina needed to setup and run CNC machine. .
13-08-2014 #3
13-08-2014 #4
One small problem
I phone the supplyer of west system resigns here in Greece and he told me that for 105 resign he only has the 206 hardener and not the 209 ( that is recomended by the members here in my cncuk). Do you think that i can do my Job with the 206 hardener and not the 209. The temperature here in Greece is 32-35 and nearly 25-30 at my worklace.
ThanksThe creative adult, is the child who survived
13-08-2014 #5
I have used the Wests System and spoken to them a couple of times. I think you really need the 209 as it has a very slow cure and that is what you need for the resin to level out. I purchased mine here : http://www.ecfibreglasssupplies.co.uk/ not many suppliers appear to stock it but can order it for you. ..Clive
13-08-2014 #6
I agree, i don't see how it would be done without the proper hardener.
I purchased mine from http://www.dansonmarine.co.uk/ and he shipped 2 packs to Spain for 17GBP for 3-4 days.
Maybe buy locally the epoxy and purchase only the hardener, have to check with them though.
For the Hiwin 20 rails the minimum width of the epoxy should be 40mm, that leaves 10mm each side of the rails, cause epoxy rises like 5mm near the edge. I made mine something like 5mm high. Used magnets 4.5mm thick at both corners both sides, to check visually whats going on and make perfect 5mm height
About the laser cut pieces, i dont see why they would charge more for the holes. I ordered mine with holes, that's was the whole point, to save time drilling precisely. Even the 4mm holes were perfect.
13-08-2014 #7
Clive_S and Syliavski thanks both for your answers
As for the holes Syliavski there is a limit about the holes that laser can cut in relation to the material thickness.
So at 10mm plate isnt easy to cut 4mm holes. Also the charge at laser cutting is according the time the machine cuts ( this of course is influenced by the length of cut, material thickness and material )
VagelisThe creative adult, is the child who survived
BUILD LOG: New build.Stell frame cnc 1500X1000.Ball screw and gearing calculations
By ba99297 in forum DIY Router Build LogsReplies: 12Last Post: 03-09-2013, 10:37 PM -
Adjustable spindle mount?
By cncJim in forum Marketplace DiscussionReplies: 2Last Post: 19-06-2013, 08:58 PM -
Your Opinion
By PWD in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 22-05-2012, 11:02 AM -
Opinion about the structure of the router ...
By C.AlveSilva in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 01-05-2012, 02:03 PM -
WANTED: adjustable tailstock
By johngoodrich in forum Items WantedReplies: 0Last Post: 29-03-2012, 07:38 PM
