This is the stuff I used, worked fine.
http://www.reactiveresins.com/syntac...poxyresins.pdfSpelling mistakes are not intentional, I only seem to see them some time after I've posted
16-08-2014 #2
Edyy, was it cheaper you said?
Did you checked the link i provided you. For sure they ship, as i have it in my garage
Here is another link, they ship also PS. deleted the last link, very expensive.
Its not only that. There are other things important for leveling the rails. The compression yeld, surface quality and precision.
27-08-2014 #3
I am confused
First of all they dont ship to Greece ( may be to other countries but not to Greece) any epoxy because it is dangerous
The Greek supplyer doesn import the 209 hardener
I find other epoxy systems but every one has different datasheet parameters
For example west system says pot life of 100gr at 22 C, other says pot life 1lt at 25 C. How to compare?
Also it is not clear what everybody mean by saying Pot life, gel time, working time. I call them . One says all the above are the same, other says they are not. I have not a way to compare.
I find one Greek supplyer that has an australian product Megapoxy HX
This product has 60 cps viscocity and working time according the greek site (english version ) datasheet 30 minutes
http://www.megapoxy.gr/index.php?pN=...ProductID=6283
and the datasheet here
http://www.megapoxy.gr/images/pdf/Me...tion_%20En.pdf
and according an australian site (english version ) datasheet
http://www.permatech.com.au/tds/megapoxy_hx_tds.pdf 60 minutes.
What i should believe?
Also its compressive strength is bigger than west system (13778 PSI vs 12000 PSI )
For sure viscocity is very low ( ten times smaller than west system) , but working time also
Thanks for your time
VagelisThe creative adult, is the child who survived
27-08-2014 #4
wait a second!
I am going to explode from epoxy knowledge these last days
I am right here where you are with my next build . I need epoxy also, so i have done some additional research, locally, i mean. $$$$ i mean versus West System
1. How many L or KG of mix you will need, add 30% at least, for errors or mistake in calculation.
The channel for 20mm rail must be 40mm wide and 5mm thick
Yesteday i read a lot of epoxy material and it seems that the minimum thickness must be 3mm at least -otherwise the forces will not spread. So what we do here at the forum 5mm is ok.
2. lets see what compression strength epoxy we really need.
Heavy duty build, like mine or yours.
2x90mm Hiwin each side, separated at least 90mm each +50mm force spread approximately each side, that 20mm wide= ((2x90+90+2x50)x20)2=14.800 mm2= 148cm2
12800psi to kg/cm2=843kg/cm2 , so we have 148cm2 x 843kg/cm2==124 764 kg . safety factor 125 tons :3= 40 ton gantry , It seems enough, yes?
2. I am at the point of buying epoxy
I found 8kg pack of Spanish epoxy that seems to fit the purpose for 140euro. I need half only. it has only 120kg per cm2 resistance, but even that is more than enough. I can spit it in half if enough for you and ship it to Greece via UPS for 20eur. I spoke personally with the guy that makes the epoxy and he told me it will be perfect for the purpose
I am waiting to speak tomorrow with another company which has very similar epoxy to WS, and slightly cheaper per kg if to buy small packs.
or i could buy more 209 hardener from UK, together with all i need for my build and ship it to you. i can ship up to 30kg for 20eur to you.
So don't waste time with the epoxy, calculate what you need and i will help you.
3. gell time is when the poxy becomes unworkable. Pot life is the same but only if you keep the mix in the pot, where it hardens faster than if spread on the rails. Thats why the confusion. the more epoxy you keep in one pot, the faster it hardens, hence they must state how many g or kg when saying gel time or pot life.
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
27-08-2014 #5
The most important parameter is the viscosity because it need to flow like water to level out and the longer the cure time (wests is 10 - 20 hours) the better as it will have more chance to level out. Also let it cure for at least 5 days. ..Clive
27-08-2014 #6
This is what it says about shipping where I got my stuff.
http://www.reactiveresins.com/index.html
"Shipping and handling
Orders over £200 sterling will be delivered free to most of Europe including the following countries Belgium, Denmark, Estonia, Finland, France, Germany, Gibraltar, Greece, Italy, Lithuania, Netherlands, Norway Poland, Portugal, Spain, Sweden, Turkey
We use various couriers in order to get the best combination of service and value for money for our customers."
Now I'm not saying you want £200 worth of epoxy but my point is they will ship it to Greece / Spain all you need do is contact them for a price.
When you click to 'buy on line' it takes you here; http://www.resinstore.com/epoxy-packs.html
The one I used was this, 'Syntac EPAFD Slow Cure Epoxy Resin Pack'
Yes it was cheaper than West SystemsLast edited by EddyCurrent; 27-08-2014 at 08:33 PM.
27-08-2014 #7
very interesting book and fast to read. http://nilsmalmgren.com/Laddas/Epoxy_handbook.pdf
from the book:
27-08-2014 #8
BUILD LOG: New build.Stell frame cnc 1500X1000.Ball screw and gearing calculations
By ba99297 in forum DIY Router Build LogsReplies: 12Last Post: 03-09-2013, 10:37 PM -
Adjustable spindle mount?
By cncJim in forum Marketplace DiscussionReplies: 2Last Post: 19-06-2013, 08:58 PM -
Your Opinion
By PWD in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 22-05-2012, 11:02 AM -
Opinion about the structure of the router ...
By C.AlveSilva in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 01-05-2012, 02:03 PM -
WANTED: adjustable tailstock
By johngoodrich in forum Items WantedReplies: 0Last Post: 29-03-2012, 07:38 PM
