    How should the test be done ? what are we looking for ?
    Just mix a very small amount, 20g in total and see if it hardens well. Should use a precision scale though. The idea is that the epoxies if don't behave well in very small quantities but behave well when mixed half kg for example, are poor quality.
    Thank for your answers.
    Syliavski also thanks for your intention to help
    I will search a little more and if i didnt find anything i will let you know.
    My last search bring me up to this company. Have a look at the page that discribes its products
    http://www.5m.cz/en/epoxy-resins/
    PR 220 (resin) with EM316 (hardener ) has 120-150 minutes pot life
    PR 220 (resin) with EM317 (hardener ) has 200-250 minutes pot life !!!! but not curing at room temperature
    Here in Greece they import only 315 hardener to be combined with PR220 resin. This hardener suppose to be the fast, but it has pot life 50-60 minutes 200 gr at 25C ( when west system 105+209 has 40-50 minutes 100gr at 22 C). When i ask about the price ( here in Greece ) they told me 22 euros+vat but am not sure if they are talking about the PR220 or PR102 resin. Have a look.
    The creative adult, is the child who survived
    Hi everybody
    Long time has passed since my last post
    It is because after summer holidays, schools starts and (as I am a school teacher-computer science) I had too much work.
    Last night I decide to restart by installing the hiwin profiled rails
    I start with X axis in order to install the master rail. I measure, I mark the holes and then drill with 4mm first and then with 4.2mm in order to tap the m5 bolts.
    Then I bolt two carriages on a steel plate st39 ( not perfectly milled yet ) and then I put the carriages on the rail. The movement isn’t very easy. As I put pressure on the plate, the movement become easier ( as cause of preload overcoming). I didn’t lubricate the rail or the carriage for this first test.
    I didn’t epoxy level the 80X80 beams (where the rails rest) as when I test them against straight edge I didn’t notice more than 0,15mm gap, so I will go on with shimming.
    My questions are
    1. Do I have to lubricate the carriages for these first test travels
    2. What will be the normal pressure for moving the carriages
    3. As I apply force in order to overcome the preload forces I hear a sound from the carriages (krrrrrrrr ) is this normal?
    Later I will come with photos and videos to show how the carriages move.
    Thanks for your time
    Vagelis
    0.15mm is a pretty huge misalignment for these sorts of rails. The datasheets specify something in the order of micrometers.
    1. I would, since if you're having trouble aligning them then you're potentially putting big forces on them, so lubrication might help prevent damage.
    2. About the same as before the rail is mounted. When a flanged carriage is bolted down to a flat surface, the carraige is often designed to distort and apply slightly more preload, so you may notice an increase in friction. However if you leave the carraiges off what they mount on for now, there should be no more friction with the rail bolted down. If there is then your rail is seriously bent.
    3. No ... sounds like the rail, or something, is bent a lot.
    Hi Vagelis,
    You will do it right, just don't be in a hurry. It's a precision work.
    Use oil not WD40!!!
    RTFM!! Download and read the Hiwin Manual. Where the say about the WD40 by the wayNot oiled makes noise but moves freely
    I told you need straight edge. Spend 60 eur and buy at least the 1meter one. It would easily show your real misalignment spots.
    Don't push anything directly, I mean the bearing blocks. Work around them so everything is straight and so that screws are in the middle of the hole. Where necessary to widen holes.
    Jonathan and Syliavski thanks for your comments.
    Syliavski i have already bought 1200mm straight edge
    I think that first i have to perfectly mill the plates where the carriages are bolted
    Using the straight edge i must then shim the rails to be perfectly flat
    Another two question
    1. I read the hiwin maual and it says ( for carriages lubrcation ) to use lithium soap base grease. Is tha a MUST or i could use oil ( and what oil ) instead of grease.
    2. Do we also lubricate the rails or only the carriages?
    Thenks for your participation
    Hi Vagelis ,
    I am happy you are on board again
    I do not think you have big preload -Z1?
    Fist I think krrr is not critical , lubricant will help to reach prrrrr.:)
    I only have an use bearing at home so I am waiting the sound result.
    The pushing force is a good feedback I suppose
    Regards
    István
    It is very possible to go on with epoxy finally as I measure gap (beam against straight edge ) nearly 0,25mm and shimming seams to be very difficult for me.
    As i had told here in Greece they import 105 west system epoxy but they don’t import 209 hardener but only 206. So i will make some experiment with other epoxies much more cheaper ( 25 euros / 1,2 kgr). Ebay supplier asks 90pounds for 1.2 kgr 105-209 system.
    The problem is that the temperature in my work place is now 16-17 celsious and it is dropping more as Decemper comes. So if i want to apply the epoxy method i will have to make a place with controlled heating system in order to keep the temperature as low as 20-21 celsious.
    Second solution will be to go on with shimming and third ( the most expensive ) to ask a friend of mine ( that builds woodcutting machines) to use one of his machines and mill my top beams in order to come in the same plane ( but this will cost).
    I want to ask
    #1 ( very important to know what I am trying for )
    When you measure the flatness of a beam ( or epoxy surface) against a straight edge, what is the acceptable tolerance-gap ( so we assume the surface is straight) . I use light to understand whether my top beams attach the straight edge. The touching points can be easily seen. But at other points althought i can see that there is no touch ( light passes through) , the 0,02mm Gap Filler cant pass through the gap. So what is the critical gap ? the light passing test ( that is less than 0,02mm ) or the 0,02mm gap filler test?
    #2
    When someone use the solution with the adjustable top beams ( without epoxy) or the shimming method how does he succeed to have the top rails in the same plane. How does he know when the two rails ( left and right ) are in the same plane? Is the thread method accurate ( the method that with the use of two threads you create the diagonals of the top rails like X. If the diagonals are in touch at the centre that means that the rails are in the same plane.
    #3
    When we use the epoxy method we first drill then tap then close the holes and then apply epoxy or we apply epoxy then drill and tap?
    #3
    What is the right angle to hold a single beveled straight edge? 90 degrees?45? something else?
    Vagelis
    Quote Originally Posted by ba99297 View Post
    1. I think if you use grease then the lithium is a must, but oil can be used, Jonathan used it here for example; http://www.mycncuk.com/threads/6484-...strong-machine
    I get the correct grease here; http://www.toolstation.com/shop/Auto...se+400g/p89691
    2. Lubricate the carriages only, they will pass lubrication onto the rails.
    #3
    #4
    3. I drilled and tapped all the holes after I poured the epoxy, there were no problems by doing this.
    4. 90 degrees because you do not want the straight edge to bend in the middle.
    I've been working on my machine this evening, and I think that we are a very similar stage of build! I was levelling the frame of my machine (similar size - cutting area about 1500x750) and thinking about epoxy. I have already bought my epoxy (Reactive Resins low-viscosity with slow hardener) but they say that it should not be used below 8C. In my part of the UK at the moment, that's about the night-time temperature and daytime is only about 12C (and probably slightly cooler in my garage).
    As well as I can measure it, I have a dip in my rails of about 1.3mm in the centre. Not as accurate as I would like - not sure if it was a bend in the original 100x50 box sections, or welding distortion - but I think that that will be fine with epoxy. However, I could shim it, if I can find some suitable material. Epoxy has the advantage of also bringing both rails into the same plane, of course, which would be much more difficult with shims (tapered shims, anyone?). What I don't know is what kind of tolerance you need to work to with Hiwin rails - what kind of relative twist in the two rails is OK? If both rails are perfectly horizontal in both planes but one is, say, 1mm higher than the other, would this matter? On my machine, that is a twist in the bearing block of about 0.06deg, or 0.001mm across the rail. Doesn't sound like a lot to me, but I have no practical experience of the real-world tolerances on these things.
    I'm planning to epoxy first and drill/tap through the epoxy and rail later. My feeling is that this will be easier, and certainly better than trying to remove the epoxy that has leaked into the tapped holes.
  1. BUILD LOG: New build.Stell frame cnc 1500X1000.Ball screw and gearing calculations
    Last Post: 03-09-2013, 10:37 PM
  2. Adjustable spindle mount?
    By cncJim in forum Marketplace Discussion
    Last Post: 19-06-2013, 08:58 PM
  3. Your Opinion
    Last Post: 22-05-2012, 11:02 AM
  4. Opinion about the structure of the router ...
    By C.AlveSilva in forum Gantry/Router Machines & Building
    Last Post: 01-05-2012, 02:03 PM
  5. WANTED: adjustable tailstock
    By johngoodrich in forum Items Wanted
    Last Post: 29-03-2012, 07:38 PM
