    dsc's Avatar
    Lives in Lincoln, United Kingdom. Last Activity: 17-06-2020 Has been a member for 9-10 years. Has a total post count of 252. Received thanks 1 times, giving thanks to others 11 times.
    Hi everyone,
    hoping someone can suggest things to try as I'm a bit lost as to why this is happening.
    I have a DM856 driver and a small Nema 23 motor, all connected to a SPS705 68VDC power supply (I was told the voltage on the PSU is a bit high for this motor, but it should run ok). This is driven via the PUL / DIR input from a custom built uC based board, which acts like a jog / test board, you press the '+ / -' buttons to turn the motor one step CW or one step CCW. If I press a button and hold it down, the pulses are generated in a cycle and the motor moves smoothly, but if I only press the button once, every now and then the motor 'clunks' or jumps a step, sometimes going reverse etc. Here's what the pulse looks like:
    The first two (from the left) screenshots show the pulse generated by the uC / electronics, pulses are 41us wide and as per the manual the DIR signal is in front of the PUL signal (DIR is not shown here). The screenshot on the right is a pulse from a pulse generator, not much different from the micro controller generated ones. With the pulse generator the motor runs smoothly, even at 1Hz :O
    Anyone got any ideas as to what might be causing the 'clunks'? the motor isn't loaded, it simply sits on a desk with nothing attached to it.
    Regards,
    T.
  1. My turn for help with Pulse multiplier for test rig.
    By JAZZCNC in forum Electronic Project Building
    Last Post: 20-06-2014, 06:09 PM
  2. MPG or Hand Wheel Pulse Encoder where to buy in UK?
    By suesi34e in forum Marketplace Discussion
    Last Post: 02-01-2014, 04:41 PM
  3. Pulse rate or dip switch settings
    By Jopo in forum Stepper & Servo Motors
    Last Post: 29-04-2013, 08:08 AM
  4. Strange problem, possibly missing steps?
    By Philly in forum Chinese Machines
    Last Post: 26-10-2012, 06:36 PM
  5. Missing Steps + Stalling X-axis
    By danielbriggs in forum Linear & Rotary Motion
    Last Post: 02-09-2010, 02:59 PM
