Thread: Validation of power supply
Swap the pin outputs---good idea, I'll do that.
All the other Q's
Have you made sure there's no feedrate adjustment in the Gcode for the circle ? is None
Is feed overide in use on the circle ? N
Have you tried feed overide to see if it makes any difference ? Same weather F/R is in Gcode or O/ride.
Does it stall\lose steps if you jog all 3 axes together or jogging 1 back and forth while jogging others ? Jog is healthy al all speeds up to max (1300mm/min)
Does it stall immediately on the Y-axis.. or only above a certain speed ? Not directly speed related, see above but would stall at a direction change
Is it a constant loss of steps.. or a single big stall ? big stall which it usaully recovers from
Are you sure the problem is restricted to a single axis ?Y
What OS are you running ? WinXP
Have you run the mach 3 optimisation ?.. i.e. switching off unused system processes. don't know. Will investagate.
Have you run the mach 3 pulse rate test on your machine ? No. will investagate
What IS your mach pulse rate on diagnostic page.. does this match set pulse rate ? Dont know
Have you run motor tuning ? No
Are you sure your axis calculations (steps per unit) for mach 3 are correct and that settings are correctly applied. Dont know, didnt calculate but reverse engineered off a ruler.
Are all motors\settings the same ?Y
Have you tried changing the origin position of the test paths along the Y axis.Y same trouble
What happens after the stall ? would it complete the motion\cut.. or stall again ? recovers until next time.
The current limiting setup on your drives may also have a bearing on this.. i.e. is current limiting built in\adjustable.. if so how.. are settings correct for all motors.. that kind of thing..
Will triple check drive settings.
Thanks for the input . I'll report the progress if/when I ever get a day off to play
Power Supply Suggestions please..
By Ricardoco in forum General ElectronicsReplies: 37Last Post: 30-01-2013, 06:37 PM -
PCPPS V3 Power Supply?
By birchy in forum General ElectronicsReplies: 4Last Post: 10-12-2012, 04:21 PM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
FOR SALE: 50V 20A Power supply
By Jimmybristol in forum Items For SaleReplies: 8Last Post: 30-05-2011, 11:01 PM -
power supply
By hitmythumb in forum General ElectronicsReplies: 6Last Post: 21-06-2009, 10:27 AM
