21-10-2013 #4
That's alright for some - i.e. the people who use AM882 drives or others with resonance damping algorithms. However if you're using a more generic drive it can help if you're having problems with resonance to use some sort of 'anti vibration' mount. Some stepper motors I got from a large plotter (nema 34 and 23), were mounted with a piece of thin neoprene rubber between the front face of the motor and the mount, with the screws inside small rubber bushings which pushed into the motor flange.
It's worth remembering that stepper motors can conduct a significant amount of heat from the mounting face, so it's a good idea to bolt them to a reasonable size piece of aluminium. Clearly putting neoprene in between is not going to do the thermal conductivity much good, so the motors will run at a higher temperature.Last edited by Jonathan; 21-10-2013 at 10:51 PM.
M542 driver - motor vibration at low speeds
By birchy in forum Motor Drivers & ControllersReplies: 34Last Post: 22-11-2013, 08:16 PM -
Calculating torque settings for bolts.
By swarf-boy in forum Machine DiscussionReplies: 2Last Post: 22-12-2010, 12:18 AM -
WANTED: Nema 23 motor mount
By D-man in forum Items WantedReplies: 0Last Post: 29-06-2010, 07:36 AM -
High Torque Motor Z Axis
By Lee Roberts in forum Stepper & Servo MotorsReplies: 5Last Post: 17-05-2009, 10:08 PM -
What stepper motor size (torque)
By ZeroCount in forum Stepper & Servo MotorsReplies: 5Last Post: 09-02-2009, 11:54 PM
