Thread: font software
    kell's Avatar
    Lives in doncaster, United Kingdom. Last Activity: 15-12-2024 Has been a member for 9-10 years. Has a total post count of 53.
    Which is the best software to use to produce fonts ready for cutting on cnc ?
    What you wanting to do with your fonts, engrave them in or cut them out?
    Quote Originally Posted by kell View Post
    The totally free to use SprutCAM 7 Express has the ability to produce text using any installed Windows font or it's own stroke fonts. You can then machine this using the 2D Contouring or Pocketing operation.
    Dave
    kell's Avatar
    To cut them out musht.
    Will take a look at sprutcam cheers
    iv found this useful for a quick fix... its free, simple to use, it will g-code the outline of any font for cutting out or drag engraving
    (it wont do any fancy variable depth V-cutter calligraphy)
    http://www.deskam.com/deskengrave.html
    Cambam lets you use any font on the pc, I just tried it last weekend.....I used a pocket then profile operation rather than the engrave option (probably the wrong way, I am just learning this stuff)
    Ian
    kell's Avatar
    This is a picture of the type of thing I am trying to achieve. I use solidworks and solidcam. The lettering in the picture is only 5mm in height.
    Quote Originally Posted by ian823478 View Post
    Ian
    CamBam also has a V engrave plugin that can be used with Windows fonts for example, https://www.atelier-des-fougeres.fr/.../Vengrave.html
    It also has a plugin to fit text onto a Polyline, https://www.atelier-des-fougeres.fr/...nPolyline.html
    There are some single line fonts for engraving here, https://www.atelier-des-fougeres.fr/...tickfonts.html
    If you have decent CAM you can already use any fonts available to your Operating System.
    There is software available to produce fonts but making fonts is a lot of work, even with the right software, it's easier to choose from the thousands already available for free download,
    - Nick
    kell's Avatar
    trying to match the one in the picture thats is all no interest in designing one.
  1. Font help, adding a stand/base to letters so they stand up
    By cockneyrebel in forum Computer Software
    Last Post: 25-07-2014, 12:57 AM
  2. Font cutting
    By petesos in forum Machine Discussion
    Last Post: 17-05-2014, 08:14 PM
  3. Hi font help please
    Last Post: 12-04-2013, 06:39 PM
  4. Replies: 2
  5. Russian single line font
    By kuki in forum Computer Software
    Last Post: 18-05-2012, 05:54 PM
