Thread: List of CAD/CAM Software
24-10-2013 #9
John,
Vectric is listed last on the top list, which in my view really does not do it justice as Vectric is a family of CAM software with one that is professional grade CAD/CAM program (mainly for Furniture, Cabinet, and sign-makers but has more uses as well). They are Cut2D (have not used), Cut3D (own and use regularly), VCarvePro v7 is current version (I own and use on many projects), PhotoVCarve (great for Lithophanes among other uses), and the top of the hill Aspire (don't own a copy yet). If you are looking for good software with solid support without a huge bill I would seriously look into these.
I also use CamBam for Engineering type 3D work (Cut3D work on a plane of a work surface and as such has some limits). Takes a bit more time to do proper set up but is a very good product. I have used others but, currently don't.
CAD side of things I use ViaCAD Pro v8 which does most of what I need done and work well with both 2D and 3D modeling. I am fortunate enough to be a beta tester for them on ViaCAD and Shark which does give me some bias but they are a good product for the cost.
Biggest issue for CAD/CAM is ROI; that and learning curve. Some of the modern CAD packages try to get folks stuck with them by having such a huge learning curve that once you have gotten over it you don't want to go through the headache again. So for a small shop I would strongly suggest going with solid programs that do the job instead of bells and whistles.
Just my 2p MichaelSoftware SolidWorks 2024, Onshape, Aspire v9.5, Blender
CNC Machine: http://www.mycncuk.com/threads/3661-...Second-machine
3D printers both FDM/FFD and MSLA resin
CSWA &CSWA-AM certified
www.marino-customs.com
Newbie. Questions about design software and machine control software
By MTech in forum Computer SoftwareReplies: 2Last Post: 11-12-2012, 12:58 PM -
CNC machinist: Most hated job list
By Robin Hewitt in forum General DiscussionReplies: 4Last Post: 27-08-2011, 01:40 PM -
Which Software
By Ricardoco in forum CAD & CAM SoftwareReplies: 41Last Post: 12-01-2011, 04:43 PM -
BobCad 80% off list
By Robin Hewitt in forum BobCAD-CAMReplies: 14Last Post: 06-08-2009, 04:25 PM
