I've spent last seven years doing Windows and Linux programming, and I'm not a bit shamed that I don't know PC assembler. I'm sure Ian is very proficient on whatever CAD and CAM program he is using.
23-10-2013 #2
It's not a criticism I'm just saying how I would be, Ian must be 'top down' whereas I'm 'bottom up' (not sure I like the sound of that). I was contemplating an ExelCnc machine myself until I decided to self build.
23-10-2013 #3
I was being just a tiny bit ironic but only a bit.
These machines are a tool of my business and , like all the other programming I do, I have learned just as much as I need to get done what I need to get done. Every now and then I need to do something new and then I learn how to do it.
Basically most of my programs are repeated thousand of times so I know enough Gcode to take the co-ordinates that Vcarve produces and turn them into parameterised routines so that I can easily adjust feed speeds cutting depths etc.
24-10-2013 #4
Hi Ian,
I'm just down the road (ish) in Crowthorne. Those ExcelCNC machines look very nice indeed would love to be able to own one but as CNC is a hobby for me (real job is in IT) that doesn't seem likely!
How do you find working with VCarve? I really like the look of it, I tried the demo version and I seemed to be able to do everything I want to do and more, but again the price is a bit high for a hobby (£400?).
Is VCarve the only software you use?
Cheers,
Jim
24-10-2013 #5
If you know how to create parametric G-code then your being a bit more than Tiny Iroinic Ian.!!! . . . Most on here wouldn't know how or were to start with Parametric G-code.! . . . 9/10 if you learnt your self this.
Regards the Excel Machine I started making machine for friends and friends of friends good while before they did which purely coincidently is very very similar(Mines better thou.
) and I nearly fell over when I spotted there machine at a show.!! . . . After thoroughly interrogating the poor Father of the Lad who started Excel I realised no industrial Spying had taken place so halted the Execution.
Obviously I knew the design was sound for the purpose it was being sold, mainly wood and plastics, but was impressed with the helpful open nature of the guys.
Was also impressed with finish of machine and good quality of components but Wasn't so impressed at the time with the mis-matched electronics.? . . . . May have changed now.? . . . But at that time it Used Good quality Gecko G540 combo drive but with 4.2A motors and seen the G540 only puts out 3.5A the machine wasn't getting the best from motors. Also running G540 with motors higher than 3.5A loses current reduction function and don't think they knew about using a resistor to trick G540.?
Other than that and the fact they where trying to charge £800 for 2.2Kw Chinese spindle/Vfd setup which cost £300 the rest was spot on and quite nice bloke.!
24-10-2013 #6
Ian,
You mentioned you do other programming, I can see how using variables in G code will seem natural to you and I'm expecting the same myself, I used to write a lot of C code for PC's in the 80's using an Amstrad 1512 then later an IBM PC clone, I also guessed you might be doing repetitive work and hence not playing with the code much.
28-10-2013 #7
had a look at the exel machines myself and got a couple of quotes, what put me off was the price and the cost of all the addons and 'extras' glad to hear you are happy with them though.
Im still researching lol.
28-10-2013 #8
CNC machines
By JMP in forum Machine DiscussionReplies: 2Last Post: 04-07-2010, 07:40 PM -
New CNC machines???
By afcpaul in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 18-09-2009, 01:46 PM -
WANTED: Anyone got any brochures on old cnc machines?
By angaengineering in forum Items WantedReplies: 0Last Post: 10-09-2009, 08:26 PM -
cnc machines
By DGH in forum Milling Machines, Builds & ConversionsReplies: 10Last Post: 24-05-2009, 10:50 AM -
TEP CNC Machines
By alan2525 in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 05-02-2008, 01:04 PM
