Thread: I want a vacuum table!
I might be wrong, but I thought you can't use a vacuum cleaner for extended periods with virtually no airflow as it relies on the air to cool the motor? Having said that, if the airflow is zero the power drawn will be less, so maybe you'd get away with it.
23-10-2013 #2
One picture shows it used with the small vacuum bed which I think is now discontinued ? no idea about duty cycle though and likely practically useless for Tenson's proposal.
http://www.trend-uk.com/en/AT/produc...tts_230v_.html
vacuum table using compressed air
By plasticman in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 25-12-2012, 05:42 PM -
Vacuum Table Advice
By Minium in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 13-11-2012, 09:52 AM -
Custom Vacuum Table 'Hold Down' System - piping/valve advice
By FlightCaseCo in forum Machine DiscussionReplies: 4Last Post: 16-01-2012, 06:56 PM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM
