Thread: I want a vacuum table!
Okay well a floor vacuum will tend to move around 3000-4000l/min so certianly a higher flow rate!
As soon as the sheet has some holes cut in it there will be a fair amount of air flow I suppose. It would only take a 3mm wide cut 600mm long to give an open area about the same as the vacuum hose. That's why I worry about using a pump as I think the sort I can afford might not manage without a really good seal. I suppose when the sheet stock is held down perfectly flat I could accurately cut just shy of all the way through helping to keep the suction up. I'd then just cut the perimeter of the piece with a knife. I think I've heard this referred to as 'onion skinning'. Kind of like tagging, but the remaining stock is not strong enough to hold the part, it just keeps the vacuum up.
This is an interesting video anyway:
vacuum table using compressed air
By plasticman in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 25-12-2012, 05:42 PM -
Vacuum Table Advice
By Minium in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 13-11-2012, 09:52 AM -
Custom Vacuum Table 'Hold Down' System - piping/valve advice
By FlightCaseCo in forum Machine DiscussionReplies: 4Last Post: 16-01-2012, 06:56 PM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM
