Thread: I want a vacuum table!
Hi Tenson, I presume that you will still be using an mdf sacrificial board on top of your new board, so why not write a program to drill a couple of screw/boltholes and secure the sacrificial board ensuring that you show to fixing position on your table to prevent hitting the fixings. I have arranged a series of clamps along the front of my table which secure both the sacrificial board and my material. these clamps are just outside the cutting area and will hold the work in the event of a vacuum failure (fingers crossed has not happened yet). the vacuum holds the job securely and I get a far better cut as the job is always held tight to the table ensuring that there is no sawdust build-up under the cut. My clamps are simply tightened with wing nuts and take only seconds to secure?release. Glad you are getting there with tour vac bed. G.
vacuum table using compressed air
By plasticman in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 25-12-2012, 05:42 PM -
Vacuum Table Advice
By Minium in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 13-11-2012, 09:52 AM -
Custom Vacuum Table 'Hold Down' System - piping/valve advice
By FlightCaseCo in forum Machine DiscussionReplies: 4Last Post: 16-01-2012, 06:56 PM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM
