Thread: I want a vacuum table!
24-10-2013 #6
Replying reference breaking through the material. I used to use low tac sign making application paper. You applied it to the rear, when the cutter cut the material, it left the paper in place thus keeping the vacuum table sealed. I used off cuts of foamex to blank off the open holes around the material, and the joy with sabre is that you can close off Channel's manually too. Hope this helps.
vacuum table using compressed air
By plasticman in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 25-12-2012, 05:42 PM -
Vacuum Table Advice
By Minium in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 13-11-2012, 09:52 AM -
Custom Vacuum Table 'Hold Down' System - piping/valve advice
By FlightCaseCo in forum Machine DiscussionReplies: 4Last Post: 16-01-2012, 06:56 PM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM
