Thread: I want a vacuum table!
12-11-2013 #10
What do you chaps think about this pump? 8.0CFM 5Pa 250W REFRIGERATION AIR CONDITIONING VACUUM PUMP + GST | eBay
It says 8CFM (240L/Min) which is about twice the other pumps I've found on eBay and it's less expensive too. Too good to be true?
Can anyone say from experience if I wanted to cut out these parts below with a 3mm cutter, what sort of flow-rate do I need from a pump to maintain a good 'suck'? If I were cutting soft materials I could leave a very thin skin to keep the vacuum up, but I often work with cast acrylic and I don't imagine I can 'skin' that so cuts would need to be full depth. The advice above of using adhesive backed paper may help me here but I just want to get an idea about flow-rate.
free uploadLast edited by Tenson; 12-11-2013 at 06:15 PM.
vacuum table using compressed air
By plasticman in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 25-12-2012, 05:42 PM -
Vacuum Table Advice
By Minium in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 13-11-2012, 09:52 AM -
Custom Vacuum Table 'Hold Down' System - piping/valve advice
By FlightCaseCo in forum Machine DiscussionReplies: 4Last Post: 16-01-2012, 06:56 PM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM
