Thread: I want a vacuum table!
Hi Tenson
If you are going to try this with your newly acquired e-bay pump i would just buy some nylon reinforced pipe the same diameter as your pump inlet, i have used mine with 10mm clear(home brew supplies) plastic and not had it flattening when i have been vacuum bagging. coupling to the vacuum bed would be better done with plastic plumbing waste.
regards
Mike
vacuum table using compressed air
By plasticman in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 25-12-2012, 05:42 PM -
Vacuum Table Advice
By Minium in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 13-11-2012, 09:52 AM -
Custom Vacuum Table 'Hold Down' System - piping/valve advice
By FlightCaseCo in forum Machine DiscussionReplies: 4Last Post: 16-01-2012, 06:56 PM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM
