    What is nylon re-enforced pipe? You mean the sort with ribs like a vacuum cleaner has?
    My pump has 5/8" inlet and so does my bed. Feed to the bed is via steel tubes so I just need to connect those to the vacuum chamber and chamber to the pump. 1m length either side should do.
    Something like this:- Clive
    Attachment 10854
    Hi Tenson
    The reinforcement is actually more for strength with internal pressure, 5/8 bore should be OK as long as it's a straight'ish run, too sharp a bend and it might flatten but i would imagine you will have enough leakage to prevent that.
    Regards
    Mike
  1. vacuum table using compressed air
    By plasticman in forum Milling Machines, Builds & Conversions
    Last Post: 25-12-2012, 05:42 PM
  2. Vacuum Table Advice
    By Minium in forum Milling Machines, Builds & Conversions
    Last Post: 13-11-2012, 09:52 AM
  3. Custom Vacuum Table 'Hold Down' System - piping/valve advice
    By FlightCaseCo in forum Machine Discussion
    Last Post: 16-01-2012, 06:56 PM
  4. Replies: 1
    Last Post: 01-01-2012, 12:34 AM
  5. DIY Vacuum Table
    By templecorran in forum Machine Discussion
    Last Post: 10-11-2010, 12:11 AM
