Thread: I want a vacuum table!
07-01-2014 #30
Well done Tenson. The covering of part of the table with an impervious sheet works well. A friend of mine has arranged a polythene "roller blind" which extends from one end of the table - he just pulls it out to whatever length he needs and that works well. To improve your suction you could use a round rubber neoprene gasket seal around the edges of the mdf sacrificial board. I know that you will find having a vac table a big advantage. G.
vacuum table using compressed air
By plasticman in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 25-12-2012, 05:42 PM -
Vacuum Table Advice
By Minium in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 13-11-2012, 09:52 AM -
Custom Vacuum Table 'Hold Down' System - piping/valve advice
By FlightCaseCo in forum Machine DiscussionReplies: 4Last Post: 16-01-2012, 06:56 PM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM
