    Thanks will have a look tomorrow downside is I do not understand electrics too well, here is the link PI8000&8100 series Frequency Inverter Manual.PDF_免费高速下载|百度云 网盘-分享*限制, looks like I got the name wrong reason you could not find it.
    If you see anything that could direct me what to do to test & reset that would be great.
    Another question should the shield of the motor cable be connected to the plug on the motor cable & to the other end say the heatsink on the VFD, when I first made the connection I did not connect the shield to the heatsink and I got noisy steppers after connecting the noise had gone, on inspecting the plug end I noticed the shield was not touching the metal plug could this have been the reason for error.
    Phill
    Normally with shielding you want it connected to the supply end only, this is to eliminate a circular path or circuit that current can flow round.
    This is a better download link, once downloaded it allows you search for "reset" for example.
    http://www.powtran.net/admin/userpic...6174210670.pdf
    Crazy though it is (price wise), if you don't have a meter this one should do the job
    http://www.ebay.co.uk/itm/Digital-Vo...item2c7390f84d
    Hi Phill
    Where about's in Derbyshire are you?
    Andy
    Quote Originally Posted by audioandy View Post
    Hi Phill
    Andy
    Just off A38 DE56
    Been trying settings on VFD and will run for 1/2 hour at different speeds then trip out with the same error, all cable ends have been remade and are tightly clamped in respective holes, just been told as it's never been used for about a year it might need charging? anyone know how to charge and if it does need too and could this be the reason why it won't run longer.
    Phill
    Hi Phill
    If you can't sort it I can have a ride over and have a quick look at it with you.
    As for the charging I have no clue what they are on about other than they may be talking about the large capacitors on the board which if they are I have never heard of that before!
    Send me a pm if you want any help with your phone number and I will give you a call.
    Regards
    Andy
    Phill,
    I hadn't picked up from your posts that it would run for a while before faulting again, I read it as though it would not work at all. The capacitor issue is called 'forming' or in this case 'reforming' it's always been an issue for quality stereo system amplifiers too.
    Have a read at this post, I put a link in there about it.
    http://www.mycncuk.com/forums/router...pping-rcd.html
  1. Bearing fit problem
    By paulus.v in forum Linear & Rotary Motion
    Last Post: 09-10-2013, 09:54 AM
  2. Problem with X
    By gorbo in forum General Discussion
    Last Post: 24-02-2011, 05:33 AM
  3. z axis problem on rye ma 1500 with a bosch cc100
    By rickybabe in forum Rye CNC Routers
    Last Post: 28-04-2010, 09:04 AM
  4. Problem with calibration
    By m.marino in forum Gantry/Router Machines & Building
    Last Post: 22-04-2010, 04:19 PM
  5. Z Problem
    By airwolf in forum Machine Discussion
    Last Post: 10-11-2009, 08:08 AM
