Thread: Powertran VFD problem
Normally with shielding you want it connected to the supply end only, this is to eliminate a circular path or circuit that current can flow round.
This is a better download link, once downloaded it allows you search for "reset" for example.
http://www.powtran.net/admin/userpic...6174210670.pdf
Crazy though it is (price wise), if you don't have a meter this one should do the job
http://www.ebay.co.uk/itm/Digital-Vo...item2c7390f84dLast edited by EddyCurrent; 24-10-2013 at 10:40 PM.
24-10-2013 #2
Hi Phill
Where about's in Derbyshire are you?
Andy
29-10-2013 #3
Just off A38 DE56
Been trying settings on VFD and will run for 1/2 hour at different speeds then trip out with the same error, all cable ends have been remade and are tightly clamped in respective holes, just been told as it's never been used for about a year it might need charging? anyone know how to charge and if it does need too and could this be the reason why it won't run longer.
Phill
29-10-2013 #4
Hi Phill
If you can't sort it I can have a ride over and have a quick look at it with you.
As for the charging I have no clue what they are on about other than they may be talking about the large capacitors on the board which if they are I have never heard of that before!
Send me a pm if you want any help with your phone number and I will give you a call.
Regards
Andy
29-10-2013 #5
Phill,
I hadn't picked up from your posts that it would run for a while before faulting again, I read it as though it would not work at all. The capacitor issue is called 'forming' or in this case 'reforming' it's always been an issue for quality stereo system amplifiers too.
Have a read at this post, I put a link in there about it.
http://www.mycncuk.com/forums/router...pping-rcd.html
Bearing fit problem
By paulus.v in forum Linear & Rotary MotionReplies: 7Last Post: 09-10-2013, 09:54 AM -
Problem with X
By gorbo in forum General DiscussionReplies: 17Last Post: 24-02-2011, 05:33 AM -
z axis problem on rye ma 1500 with a bosch cc100
By rickybabe in forum Rye CNC RoutersReplies: 3Last Post: 28-04-2010, 09:04 AM -
Problem with calibration
By m.marino in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 22-04-2010, 04:19 PM -
Z Problem
By airwolf in forum Machine DiscussionReplies: 2Last Post: 10-11-2009, 08:08 AM
