Thread: How are these made...
Honestly I can think of a bout three ways to build that and have it hold a light load of weight. Being mdf and rather shallow depth I would say that built as a square and then inner corners glued in and the outer routered off on a moulding spindle. Would be the fastest method for production, unless there was a high cost for labour, but I bet there isn't. -Michael
Software SolidWorks 2024, Onshape, Aspire v9.5, Blender
CNC Machine: http://www.mycncuk.com/threads/3661-...Second-machine
3D printers both FDM/FFD and MSLA resin
CSWA &CSWA-AM certified
www.marino-customs.com
24-10-2013 #2
I would think MDF could be formed into many shapes other than flat sheets.
"MDF is a type of hardboard, which is made from wood fibres glued under heat and pressure."
25-10-2013 #3
Thanks Eddy !
I had thought about the MDF forming as being a possibility, I just can't see how it'd have been made using sheets of MDF (because of the obvious depth of the box) unless it was cut into four pieces and then joined?
26-10-2013 #4
Hi Jas
Browse these videos.
My guess is a thin formed shell with some sort of light weight core, maybe foam or cardboard, for your shelf.
https://www.google.com.au/?gfe_rd=ct...e+IKEA+factory
Or maybe this search.... Note Minus -Ikea in the search
https://www.google.com.au/?gfe_rd=cr...+factory+-ikea
Regards
JohnLast edited by John McNamara; 26-10-2013 at 08:41 AM.
31-10-2013 #5
Based on a pic I see in this auction, they're particle board, not MDF.
Wall Decor Shelf Shelves MDF Interior House Room Cube Round Shelf Hidden Bolt | eBay
It would appear that they are molded into that shape from the factory. There's no possibly way to make that from flat sheets and still make any money on it. Even for those working for $2/day.Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
31-10-2013 #6
They are only 20cm deep. I suspect they may be a simple vacuum forming, made from a heated sheet with vacuum over a former, then foam filled to give rigidity. A common process in industry.
https://www.google.com.au/?gfe_rd=ct...vacuum+forming
Regards
John
31-10-2013 #7
Nice question Jas! Molded into that shape and laminated with plastic? Impossible to get a smooth finish by molding. The particle board has a core layer made of larger particles and a surface layer made of smaller ones.
EXPERIENCE: Z Plate made by DOM
By dudz in forum Trading Experience & FeedbackReplies: 0Last Post: 28-11-2012, 08:12 PM -
Nut solution made easy
By Swarfing in forum Machine DiscussionReplies: 0Last Post: 08-02-2011, 10:52 PM -
Home made (easy ? ) MPG
By Buba b in forum General ElectronicsReplies: 7Last Post: 20-12-2010, 11:07 PM -
Home made CNC for 50 €
By Lee Roberts in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 26-05-2009, 08:12 PM -
Made a stand for my mill...
By irving2008 in forum Woodworking Project ShowcaseReplies: 15Last Post: 02-01-2009, 11:50 PM
