19-02-2014 #11
Any info on the lased diode side of things ? such as what's required and how it goes together ?
19-02-2014 #12
Here is some information on the setup. http://www.picengrave.com/Laser%20Setups.pdf
If you want to read how it all started from the beginning and follow how it progressed to what we are doing now, there is allot of information in these threads. These forum posts is how most everything is documented. I even have to go back to them at times for reference.
Vectric Forum • View topic - Can PhotoVcarve be used to Laser engrave on a CNC Router????
Vectric Forum • View topic - Not Just Another Laser Engraving with PVC
Diode Lasers. - Oldal 3 - Fórum
PicDither - PicEngrave - PicLaser. - Fórum
JeffExtensivly Re-worked/Re-designed/Modified Servo K2CNC KG-3925,
Mini Laser Diode Engraver and PicEngrave Pro 4 + Laser
Shapeoko 2 Laser Diode Engraver-Analog/TTL
PicLaser Lite; Image to Gcode for 9g grbl/Mach3 controllers-Laser/Spindle
PicEdit Lite: Image editing for use with PicLaser Lite
PicSender: Streams 9g grbl Raster/Vector Engraving gcodes
https://picengrave.com
The Following User Says Thank You to JJWMACHINECO For This Useful Post:
24-12-2015 #13
Happy Holidays
26-12-2015 #14
what are you engraving, wood or steel?
26-12-2015 #15
On wood with a laser diode.
26-12-2015 #16
a 445nm laser is pretty good for burning/marking wood.
you can get single mode 445 diodes which have a better beam but are lower powered or high powered diodes but they are multi modal and don't have good beams. you would need to do some testing to determine which diodes and lens combination give the best results.
google dtr lasers he sells diodes and lens
26-12-2015 #17
I guess you did not realize we are the experts in this field. Go to our web site and check it out. https://picengrave.com
26-12-2015 #18
your on photonlexicon forum and so am I ;-)
26-12-2015 #19
27-12-2015 #20
Yep, that's me.
Laser diode module machine addon
By luke11cnc in forum Laser Machines & BuildingReplies: 12Last Post: 06-01-2014, 11:24 PM -
eBay: Kress 1050 FME router with collets & 43mm mount with laser diode
By Tom in forum Items On eBay UKReplies: 0Last Post: 12-11-2013, 09:31 PM -
NEW MEMBER: engraving
By pontinal in forum New Member IntroductionsReplies: 3Last Post: 11-05-2012, 01:02 PM -
PCB Engraving / Cutting
By jrob3rts in forum General DiscussionReplies: 6Last Post: 02-06-2011, 09:35 PM -
Laser Diode Constant Current Driver
By Mad Professor in forum General ElectronicsReplies: 8Last Post: 21-07-2010, 06:01 PM
