    Here is some information on the setup. http://www.picengrave.com/Laser%20Setups.pdf
    If you want to read how it all started from the beginning and follow how it progressed to what we are doing now, there is allot of information in these threads. These forum posts is how most everything is documented. I even have to go back to them at times for reference.
    Vectric Forum • View topic - Can PhotoVcarve be used to Laser engrave on a CNC Router????
    Vectric Forum • View topic - Not Just Another Laser Engraving with PVC
    Diode Lasers. - Oldal 3 - Fórum
    PicDither - PicEngrave - PicLaser. - Fórum
    Jeff
    Extensivly Re-worked/Re-designed/Modified Servo K2CNC KG-3925,
    Mini Laser Diode Engraver and PicEngrave Pro 4 + Laser
    Shapeoko 2 Laser Diode Engraver-Analog/TTL
    PicLaser Lite; Image to Gcode for 9g grbl/Mach3 controllers-Laser/Spindle
    PicEdit Lite: Image editing for use with PicLaser Lite
    PicSender: Streams 9g grbl Raster/Vector Engraving gcodes
    https://picengrave.com
  2. The Following User Says Thank You to JJWMACHINECO For This Useful Post:
  3. #2
    Happy Holidays
Name:	happy holidays.jpg
  4. The Following User Says Thank You to JJWMACHINECO For This Useful Post:
  5. #3
    what are you engraving, wood or steel?
  6. #4
    On wood with a laser diode.
  7. #5
    a 445nm laser is pretty good for burning/marking wood.
    you can get single mode 445 diodes which have a better beam but are lower powered or high powered diodes but they are multi modal and don't have good beams. you would need to do some testing to determine which diodes and lens combination give the best results.
    google dtr lasers he sells diodes and lens
  8. #6
    Quote Originally Posted by andy_con View Post
    I guess you did not realize we are the experts in this field. Go to our web site and check it out. https://picengrave.com
  9. #7
    your on photonlexicon forum and so am I ;-)
  1. Laser diode module machine addon
    By luke11cnc in forum Laser Machines & Building
    Last Post: 06-01-2014, 11:24 PM
  2. Replies: 0
    Last Post: 12-11-2013, 09:31 PM
  3. NEW MEMBER: engraving
    By pontinal in forum New Member Introductions
    Last Post: 11-05-2012, 01:02 PM
  4. PCB Engraving / Cutting
    By jrob3rts in forum General Discussion
    Last Post: 02-06-2011, 09:35 PM
  5. Laser Diode Constant Current Driver
    By Mad Professor in forum General Electronics
    Last Post: 21-07-2010, 06:01 PM
