    Yes it is, I'll make sure what version I saved it as. I am using 2013
    track plate 2004
    this was saved as a 2004 version
    Lives in Marple Stockport, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Rebekah_harper View Post
    track plate 2004
    I have opened it now but if you are learning cnc I think you will find that that part will be difficult to machine and I am sorry but is beyond me at this time. I think you will need a Cam program to convert it to gcode. But I am sure somebody will step in and help out. Good luck. ..Clive
    Ok, thank you for trying.
    Good thing is that I am gaining control of cad software.
    Just need a cam program that will deal with 3d parts
    Can any one test this part so I know if it the design or the cam software.
    I tried BamCam but the part doesn't even appear.
    I can open it up in Autocad and see the rail has been extruded but It appears there are no 3D faces, when DFX is imported into Artcam pro, (reads no 3D triangle data)
    Phill
    It opens fine in Solid works just the curved surfaces are not so smooth and made from straight lines. (Maybe meant to be that way.?)
    To create this then I'd would do it mostly with 2D toolpaths and just use 3D for the curved surfaces. Depending on material then could even be done with all 2D toolpaths if profiled tooling was created or found, this would greatly speed up the cutting time.
  1. Replies: 1
    Last Post: 20-10-2012, 02:50 PM
  2. Mach3 Using a physical button to repeat current gcode
    By RLKS Rob in forum Artsoft Mach (3 & 4)
    Last Post: 12-08-2012, 01:30 PM
  3. gcode stops mid way can anyone test..
    By crossleymarko in forum CAD & CAM Software
    Last Post: 22-04-2012, 12:45 AM
  4. Tapping Gcode
    Last Post: 14-12-2010, 07:07 PM
  5. PLease help - gcode newbie
    By scotty in forum Programmers Corner
    Last Post: 07-03-2010, 12:48 PM
