  1. #6
    Hi
    I just wondered if anyone else has used a tractor type "pinion" on a belt rack?
    The small belt is double sided and is quite wide but the belt rack needs to be even wider, this allows for clamping it to the frame.
    The belt rack can be any length you like.
    I have found that there is no backlash as the tractor is totally engaged with the toothed pulley and the belt rack at the same time.
    This type of setup will move a lot of weight, quite quickly if you want it to.
    Try to design the frame and the rack so that the belt rack is facing downwards, this helps to keep it clear of waste materials.
    However that is not easy to do.
    I hope this helps to someone.
    I can forward the suppliers name and address if required.
    regards
    Montegoman
  1. BUILD LOG: 10ft x 5ft Rack & Pinion, BIG BUILD
    By andrewbond in forum DIY Router Build Logs
    Last Post: 03-03-2014, 09:20 PM
  2. z axis rack and pinion advice
    By marbles in forum Gantry/Router Machines & Building
    Last Post: 09-01-2013, 11:41 PM
  3. Rack and Pinion MOD 1 & MOD 2 diffrence
    By D-man in forum Rack & Pinion Systems
    Last Post: 07-11-2012, 03:29 PM
  4. Rack and Pinion
    By pmcb1011 in forum Rack & Pinion Systems
    Last Post: 31-05-2011, 11:55 AM
  5. Headsup for the Hemsworthlad! Rack and Pinion
    By Smiler in forum Rack & Pinion Systems
    Last Post: 14-06-2009, 11:36 PM
