06-11-2013 #13
There's always going to be a flat of some sort, but for the tool you linked to I expect it would be neglegible. You might as well use the formula with the flat in your program, and just set f to 0 if the flat is insignificant as that results in the same formula as for without a flat.
If you've got the tool to hand, then one way to measure the flat is to spin it round and move the Z-axis down until it just touches. Retract the Z-axis and measure the diameter of the circle left - that's your f.
It's temping to link people to that quite often
WANTED: Engraving Machine to engrave around 0.3mm depth, DXF files on aluminium, anyone?
By stuboy in forum Items WantedReplies: 0Last Post: 05-12-2013, 07:28 PM -
Will this end-mill plunge?
By Tenson in forum Tool & Tooling TechnologyReplies: 10Last Post: 26-02-2013, 04:40 PM -
Z axis not cutting to required depth
By dinasblu in forum Machine DiscussionReplies: 10Last Post: 02-07-2012, 05:38 PM -
Taking the plunge
By Robin Hewitt in forum Computer SoftwareReplies: 0Last Post: 14-05-2010, 01:22 AM -
End mill depth 'stop' rings
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 10Last Post: 24-02-2010, 02:03 AM
