    With Excel you have to remember that the TAN() function uses Radians for the angle so the PI()/180 is to change the angle into radians.
    So if you use just a calculator it would be (requiredDiameter/2) X tan(angle in degrees)
    These are the angles reffered to.
Name:	v cutter.JPG
  2. The Following User Says Thank You to EddyCurrent For This Useful Post:
  3. #2
    Ah I see, thanks for that eddy, good to know!
    I am using the formula with PHP for a web application and the TAN() function uses radians so I am sorted!
Name:	v cutter.JPG
    Just spotted your diagram with the angles, I think i had the wrong angle in mind...
    So...if my cutter has a 45 degree angle at the cutting head (top of your diagram) that would mean the angle I need to use with the formula would be 67.5?
    (180-45)/2 = 67.5
    Is that correct?
  5. #4
    V-cutters are generally specified by the included angle, i.e. the angle at the tip. In that case the formula is:
    Z=d/(2*tan(a/2))
    Where:
    Z=depth of cut
    d=diameter cut
    alpha=tip angle, as above.
    So for example, lets say you have this cutter:
    4x40°x0, 1mm V-type Solid Carbide Engraving Tool Cutter f. CNC Engraving Machine | eBay
    The angle is 40 degrees, so suppose you want to cut 1mm wide:
    Z=1/(2*tan(40°/2))=1.37mm
    However, there's an error since we've assumed the cutter has a sharp point when in reality it's got a flat, which makes things marginally more interesting, hence why I decided to make this post.
    The formula you now need is as follows:
    Z=(d-f)/(2*tan(a/2))
    Using the same example, the tip flat is 0.1mm so:
    Z=(1-0.1)/(2*tan(40/2))=1.24mm
    There's also the chance that you're using V-cutters with a radiused tip.
    Now the formula you'd need is:
    Z=r-(r^2-d^2/4)^0.5, for Z<=2r [Note this is also valid for ballnose cutter]
    Z=r+(d-2r)/(2*tan(a/2)), for Z>2r
    Where r=tip radius.
    e.g. suppose this tool:
    3x20°x1mm V-type with radius Engraving Cutter graver HM for CNC engraver machine | eBay
    It's 20°, and 1mm tip radius so a=20, r=1. Lets say you want to cut 2.5mm wide:
    2.5>2*1, therefore:
    Z=1+(2.5-2*1)/(2*tan(20/2))=2.42mm
    Suppose you want to cut 1mm wide:
    1<2*1, therefore:
    Z=1-(1^2-1^2/4)^0.5=0.13mm
    Edit: If you don't have a calculator to hand, then using google is a quick way to evaluate it, e.g.
    http://lmgtfy.com/?q=1%2B(2.5-2*1)%2...20%2F2+degrees))
    You could of course just draw it in a CAD program, but where's the fun in that?
  6. The Following User Says Thank You to Jonathan For This Useful Post:
  7. #5
    Touch the tool off at the required Dia that you can measure on the part ---- and program machine to cut to the Face -no trig needed but approach move should include room for the tip -very common practice on combo tools
  8. #6
    Quote Originally Posted by Ulsterman View Post
    Thanks for the advice Ulsterman, but in this case I really am after the trig as I am coding an application to produce g-code.
  9. #7
    V-cutters are generally specified by the included angle, i.e. the angle at the tip. In that case the formula is: ......
    Thank you Jonathan, that is excellent information, just what I need! Will take me a little time to fully digest but will be worth it.
    I didn't consider the flat spot at all. Wouldn't have been a disaster, but wouldn't have been correct either!
    I asume if I use an insert v bit (such as CNC V Groove Miter Fold & Signmaking Insert Router Bit by Amana Tool) then I could just use Z=d/(2*tan(a/2)) as there would be no flat spot?
    The radiused tip/ballnose cutter was also a great thought. I was only considering supporting v cutters but I think you have changed my mind.
    Thanks!
    (haven't seen "LetMeGoogleThatForYou" before! Almost spat coffee on my keyboard when I clicked it!)
  10. #8
    Quote Originally Posted by cncJim View Post
    There's always going to be a flat of some sort, but for the tool you linked to I expect it would be neglegible. You might as well use the formula with the flat in your program, and just set f to 0 if the flat is insignificant as that results in the same formula as for without a flat.
    If you've got the tool to hand, then one way to measure the flat is to spin it round and move the Z-axis down until it just touches. Retract the Z-axis and measure the diameter of the circle left - that's your f.
    It's temping to link people to that quite often
  11. #9
    There's always going to be a flat of some sort, but for the tool you linked to I expect it would be neglegible. You might as well use the formula with the flat in your program, and just set f to 0 if the flat is insignificant as that results in the same formula as for without a flat.:
    Thats exactly what I will do, thanks again Jonathan
  1. Replies: 0
    Last Post: 05-12-2013, 07:28 PM
  2. Will this end-mill plunge?
    By Tenson in forum Tool & Tooling Technology
    Last Post: 26-02-2013, 04:40 PM
  3. Z axis not cutting to required depth
    By dinasblu in forum Machine Discussion
    Last Post: 02-07-2012, 05:38 PM
  4. Taking the plunge
    By Robin Hewitt in forum Computer Software
    Last Post: 14-05-2010, 01:22 AM
  5. End mill depth 'stop' rings
    By HankMcSpank in forum Tool & Tooling Technology
    Last Post: 24-02-2010, 02:03 AM
