    Put the return track cover back on.
    Put a light film of grease inside the nut.
    Stick all the balls into the nut in the correct places.
    Make a roll of shim just under the core diameter of the nut and balls and then slide the nut onto it making sure the balls stay in place.
    Offer this up to the screw and wind the nut back onto the screw shaft making sure the nut is the right way round.
    If necessary, wash the grease out with paraffin and apply the correct lube.
    Sit back, drink beer.
    dsc's Avatar
    Lives in Lincoln, United Kingdom. Last Activity: 17-06-2020 Has been a member for 9-10 years. Has a total post count of 252. Received thanks 1 times, giving thanks to others 11 times.
    Thanks for the tips gents. I've tried the magnet method, but the magnet wasn't powerful enough and so I ended with half the balls out again. This means I will go down the grease route and stick all the balls in manually.
    Regards,
    dsc.
  1. Belts or Balls getting me Screwed up! Help I need advice Please.
    By longy in forum Belt Drive, Pulleys & Timing
    Last Post: 15-04-2014, 02:46 PM
  2. How to get the balls back in a ballnut?
    By Shinobiwan in forum Lead Screws, Nuts & Supports
    Last Post: 24-03-2013, 04:35 PM
  3. Balls, balls and balls
    By Swarfing in forum Marketplace Discussion
    Last Post: 21-03-2013, 08:45 PM
  4. X2 change balls crews or not?
    By Oldie45 in forum Sieg Milling Machines
    Last Post: 17-08-2011, 07:55 PM
  5. Lost my balls!!!
    By danielbriggs in forum Lead Screws, Nuts & Supports
    Last Post: 19-08-2010, 02:41 PM
