Ok got the ballnut greased, divided all the balls into three groups with even amount in each and put them in the three circuits, making sure everything is nice and tidy. Carefully used a piece of ali tubing which came with the ballnut, to secure the balls in place ie. slid the ballnut over the tube making sure not to knock any balls out. Pressed the tube against the ballscrew and 'screwed' the ballnut on. It ran fine but I could hear some rattling in the ball nut like before (as if there's a ball stuck in an unused circuit), so I took the ballnut off by unscrewing into the tubing and removed the tubing carefully to inspect. Found nothing, all where it should be, so again I made sure all the balls are pressed against the races, put the tubing back in, screwed the ballnut onto the ballscrew and same thing, rattling and the ballnut stops on its own when you spin it.
Any ideas what it can be? I'm almost sure the balls are where they should be and I've seen this before when I had all balls in the ballnut. If I leave 3 or so out, it runs smooth.
Regards,
dsc.
Belts or Balls getting me Screwed up! Help I need advice Please.
By longy in forum Belt Drive, Pulleys & TimingReplies: 15Last Post: 15-04-2014, 02:46 PM -
How to get the balls back in a ballnut?
By Shinobiwan in forum Lead Screws, Nuts & SupportsReplies: 16Last Post: 24-03-2013, 04:35 PM -
Balls, balls and balls
By Swarfing in forum Marketplace DiscussionReplies: 15Last Post: 21-03-2013, 08:45 PM -
X2 change balls crews or not?
By Oldie45 in forum Sieg Milling MachinesReplies: 7Last Post: 17-08-2011, 07:55 PM -
Lost my balls!!!
By danielbriggs in forum Lead Screws, Nuts & SupportsReplies: 26Last Post: 19-08-2010, 02:41 PM
