Does anyone know where i can find belt and pulley for a spindle drive?
theres loads of suppliers mentioned on the forum try the search button
heres one
Timing Pulleys
11-11-2013 #3
Maybe it's a flat belt like my pin router ?
Transdev Transflat polychloroprene high precision flat power transmission belts
Flat Belt Drive Products IndexLast edited by EddyCurrent; 11-11-2013 at 11:15 PM.
12-11-2013 #4
Thankyou guys!
I am going to use it for a cnc spindle drive using a brushless RC outrunner.
To be honest i havent got a clue about which type of belt i need but i was hoping that the supplier could help me out.
The motor is going to run at max 4800 rpm and the spindle about 2,5 x 4800.
12-11-2013 #5
Got that on my list!! What size motor do you plan to use and will you regulate it with a servo tester? Also be interested in power source please. LiPo`s?
12-11-2013 #6
I am going to build two spindles. One with a belt drive for milling MDF, wood and softer materials. The other one with a direct drive for aluminium.
I will use a 220V power source. Right now im looking at 12-18V and 500 W. I will use as powerful outrunner motor as the power source can handle.
Maybe about 250-300 kv. That will give max 5400 rpm direct and more with belt and pulleys.
Yes, i will regulate them with an ESC and a servo tester.Last edited by JW1977; 12-11-2013 at 08:03 PM.
The Following User Says Thank You to JW1977 For This Useful Post:
Timing Pulley/Belt sizing software
By m_c in forum Computer SoftwareReplies: 4Last Post: 12-04-2014, 03:33 PM -
pulley center distance vs. belt tension
By dsc in forum Belt Drive, Pulleys & TimingReplies: 5Last Post: 13-01-2014, 10:48 PM -
PC cannot find CD ROM ?
By manofgresley in forum Computer HardwareReplies: 3Last Post: 06-12-2013, 02:35 PM -
pulley ratios on 3 pulley axis
By Swarfing in forum Belt Drive, Pulleys & TimingReplies: 35Last Post: 21-07-2011, 12:43 AM -
Belt drive and pulley sizes
By j2sip in forum Belt Drive, Pulleys & TimingReplies: 22Last Post: 20-06-2010, 10:44 AM
