  1. #18
    If you're relying on Mach for threading, then you don't need closed loop. Mach only needs, and can only handle a single pulse per revolution, which it then uses to control the Z-axis, so the spindle itself doesn't have to run closed loop. The spindle just has to maintain a relatively constant speed, to ensure things remain in sync.
    One pulse per revolution is closed loop, just not a very good one! You don't need a position loop though, just speed. I'd have thought using an external driver with a reasonably high resolution encoder would be better since the driver will be able to do a much better job of holding the speed constant (and ensuring the average is exact) than Mach3 with one 1ppr.
    Quote Originally Posted by deisel View Post
    But im unsure what determines a drive works with a brushed motor and not brushless and vice verser
    some state there for one or the other and others don't mention it, my motors brushed .
    If they don't mention it anywhere, that's surprising, but you can always count the terminals and look at the labels. In general, four terminals means it's a stepper driver, three terminals (UVW) means it's a 3-phase brushless driver and two terminals will be a DC driver. There are rare exceptions.
  1. Boxford TUD conversion Mach USB
    By Stucncusb in forum Boxford Lathes
    Last Post: 21-06-2016, 09:40 PM
  2. Mach lathe spindle speed control
    By GeoffV in forum Artsoft Mach (3 & 4)
    Last Post: 21-05-2014, 08:34 AM
  3. WANTED: Looking for a MKII Boxford duet for conversion to Mach 3
    By BlueBot in forum Items Wanted
    Last Post: 20-05-2014, 06:07 PM
  4. DYNA Mechtronics Dyna Myte 3000 lathe
    By dazza in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 12-11-2013, 08:05 PM
  5. 800x600 Mach 3 Lathe screens?
    By cooliced in forum Artsoft Mach (3 & 4)
    Last Post: 22-08-2010, 10:19 PM
