    Thanks for explaining that m_c
    To anyone ,will this be sufficient running my spindle motor http://cgi.ebay.com/ws/eBayISAPI.dll...tchlink:top:en I would also use a braking circuit.
    spoke to the seller yesterday and says the drive will be about 140v output due to 10-12% power loss on the bridge of the drive
    But im unsure what determines a drive works with a brushed motor and not brushless and vice verser
    some state there for one or the other and others don't mention it, my motors brushed .
    Lives in East Lothian, United Kingdom. Last Activity: 23 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,987. Received thanks 373 times, giving thanks to others 9 times.
    Quote Originally Posted by deisel View Post
    To anyone ,will this be sufficient running my spindle motor DG4S 16035 Positioning DC Servo Drive Mach3 CNC | eBay I would also use a braking circuit.
    That drive should work. However you need to ensure you have an incremental encoder, that outputs a quadrature signal (usually referenced as A & B outputs). You'll need to figure out eaxctly what the existing feedback device is, to see if it'll be any use.
  1. Boxford TUD conversion Mach USB
    By Stucncusb in forum Boxford Lathes
    Last Post: 21-06-2016, 09:40 PM
  2. Mach lathe spindle speed control
    By GeoffV in forum Artsoft Mach (3 & 4)
    Last Post: 21-05-2014, 08:34 AM
  3. WANTED: Looking for a MKII Boxford duet for conversion to Mach 3
    By BlueBot in forum Items Wanted
    Last Post: 20-05-2014, 06:07 PM
  4. DYNA Mechtronics Dyna Myte 3000 lathe
    By dazza in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 12-11-2013, 08:05 PM
  5. 800x600 Mach 3 Lathe screens?
    By cooliced in forum Artsoft Mach (3 & 4)
    Last Post: 22-08-2010, 10:19 PM
