06-05-2014 #21
This thread on CNCzone says it has A,B outputs and an index pulse with 5V supply voltage, so that's ideal. The second schematic you posted has the connection diagram for the encoder. That's sufficient - so long as you still have the same connector on the encoder and know which is pin 1 (i.e. which way round it goes)? If this guy responds that would help if you don't know which way round.
Edit: Helpful post about these encoders on CNCZone here:
Just noticed I've got an old (big) DC-motor with a HEDS-6300 encoder on it, so I'll try it when I've got time...
Edit 2:
Found a datasheet for the HEDS-5000 series encoders. I've uploaded it here. From the part numbering mentioned above, it seems that the 6000 series are the same just in a bigger package, so we can probably assume the pinout is the same...check it vs the schematic you posted.Last edited by Jonathan; 06-05-2014 at 01:21 PM.
Boxford TUD conversion Mach USB
By Stucncusb in forum Boxford LathesReplies: 1Last Post: 21-06-2016, 09:40 PM -
Mach lathe spindle speed control
By GeoffV in forum Artsoft Mach (3 & 4)Replies: 7Last Post: 21-05-2014, 08:34 AM -
WANTED: Looking for a MKII Boxford duet for conversion to Mach 3
By BlueBot in forum Items WantedReplies: 0Last Post: 20-05-2014, 06:07 PM -
DYNA Mechtronics Dyna Myte 3000 lathe
By dazza in forum Lathes, Lathe Rebuilding & ConversionsReplies: 0Last Post: 12-11-2013, 08:05 PM -
800x600 Mach 3 Lathe screens?
By cooliced in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 22-08-2010, 10:19 PM
