17-11-2013 #2
OK....so how would I home the tool to a work piece?
Also, can someone please clarify the directions of drives in relation to axis movement? I had assumed that on the X-axis, the table would travel from right to left when in +dir, the Y-axis would travel from the front (nearest handle) to the back (nearest column) when in +dir and the Z-axis would be travelling vertically down in +dir. Is that correct, incorrect, or does it simply depend on whatever we want our machines to do? Are there conventions, or do we just build whatever seem right?
WANTED: cnc milling machine
By bigred5765 in forum Items WantedReplies: 14Last Post: 25-04-2014, 11:08 PM -
WANTED: X3 CNC milling machine
By Nemo1966 in forum Items WantedReplies: 1Last Post: 09-11-2013, 10:42 PM -
RFQ: CNC Routers and Milling Machine Set-up
By oosk2k6 in forum Projects, Jobs & RequestsReplies: 12Last Post: 05-07-2013, 06:01 PM -
larger home made milling spindles - NMTB/ R8 taper?
By jonnydeen in forum Tool & Tooling TechnologyReplies: 6Last Post: 13-09-2012, 11:17 AM -
First CNC milling machine help
By newtoid1986 in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 05-09-2011, 10:06 PM
