    I have 3 m542 steppers, 33v power supply and the following three steppers for my x,y,z axis; Vexta steppesr:
    X= PK 296-02AA (2 Phase 1.8° step, DC, 3A)
    Y: PK268-03A (2 Phase 1.8° step, DC, 3A)
    Z: PK268-03A (2 Phase 1.8° step, DC, 3A)
    and a 5 axis breakout board like this one Click image for larger version.
    What setting on the DIP switches should I be setting Click image for larger version.
    Also what setting should I be setting in Mach3 in the motor tuning section.
    The travel of the x axis is 80mm per revolution of the x stepper motor if this is required for setting calculations.
    Thanks in advance for any help or advice. More info on my DIY build/retrofitting can be found here http://www.mycncuk.com/forums/diy-cn...html#post51435
    I'm not an expert in this but for a start I would use these settings.
    sw1 - ON
    sw2 - ON
    sw3 - OFF
    sw4 - ON
    sw5 - ON
    sw6 - ON
    sw7 - OFF
    sw8 - ON
    In Mach3 put the "steps per" at 20
    keep the acceleration and velocity low for now.
    I wouldn't use Eddy's settings. (Sorry Eddy no offence)
    Motors are 3A so go to nearest lowest not higher. . .So 2.8A going higher can lead to hot motors.
    sw1-off
    sw2-off
    sw3-on
    Currant mode is for when motors are at stand still so set to Half current mode and they won't get red hot.
    sw4-off
    Micro stepping will depend on few factors like PC speed and parallel port speed etc so I'd start lower first. So 800 Micro steps.(1/4 stepping)
    sw5-on
    sw6-off
    sw7-on
    sw8-on
    If your parallel port can stand the strain then having higher micro stepping gives smoother running motors and lessens chance for resonance.
    Are you sure it's 80mm per revolution.? That's a large pitch and low resolution.!! . . . . If correct then use 10 in Steps per in Mach. (80mm/800Ms=10steps per/mm)
  1. Random G-code for testing motor tuning.
    By Jonathan in forum Stepper & Servo Motors
    Last Post: 30-10-2019, 08:22 AM
  2. Pulse rate or dip switch settings
    By Jopo in forum Stepper & Servo Motors
    Last Post: 29-04-2013, 08:08 AM
  3. Switch for motor?
    By newtoid1986 in forum Electronic Project Building
    Last Post: 27-06-2012, 03:37 PM
  4. Help please with motor tuning mach 3.
    By Kevin1970 in forum Artsoft Mach (3 & 4)
    Last Post: 13-06-2012, 10:22 PM
