Thread: Cutting metal shapes
Hello everyone
What I would like to do is cut small shapes from metal plates, mostly aluminium but at lower grades like 1050 and about 16gauge / 1.4mm thick as it would be used for jewellery.
It would be small designs and shapes, circles stars etc on average about 1" diameter.
Now I thought I found the perfect machine with a cheap Chinese cnc router but after a fair bit of reading it would seem that it's not the best machine for the job on softer metals.
Is there a machine out there that would be suitable for this? Have a budget of about 2-3000.
Thanks very muchLast edited by jmac80; 21-03-2018 at 12:44 AM.
24-11-2013 #2
Hello and wellcome to the site. I think that you will find that a small, but rigid cnc mill will be better than a router and there will certainly be some used (already converted) machines available within your budget. good luck with your search. G.
24-11-2013 #3
25-11-2013 #4
24-11-2013 #5
If you can choose the grade then don't choose 1050, as it's difficult to cut. You'd be better off with 6082 for instance.
To get the 'perfect machine' for that budget, you'd need to make your own. A CNC mill would be acceptable, but it would be much better if a high speed spindle was added as you'll be using very small cutters.
The Chinese CNC routers you see on eBay are fine for the engraving, but they would take a long time to cut out the part. If you're making lots of these then you want a better machine. If it's just a few here and there then go for it...
24-11-2013 #6
so how on earth do people cut stuff like this from thin 1000 series aluminium
Aluminum Metal Blanks 20 Gauge Hearts for Hand Stamped Jewelry 20mm | eBay
5 Metal Stamping Blanks 20 Gauge Aluminum Washers for Hand Stamped Jewelry 3 4" | eBay
Aluminum Metal Blanks 20 Gauge 1 2" Blanks for Hand Stamped Jewelry | eBay
24-11-2013 #7
If I had to produce large quantities of those I'd CNC press tooling for my Fly Press. It's a substantial initial investment in time, tool steel and heat treatment but the payoff is making a part in less than a second with a short pull on the press handle.
If you were really posh you could also have press tooling trim off the waste from the previous part, along with a back guide and an end stop the work would then be self-aligning in the press ;-)
Regards,
Nick
24-11-2013 #8
They're stamped, like this:
Metal Stamping - YouTube
Can do it with a fly press if it's small...
24-11-2013 #9
So lol.............
Can i do it on a machine for under 2k?
the largest i would need to stamp is maybe 3" (if that)
24-11-2013 #10
Yes,
But you'll have to shop around ;-)
I picked up a nice but slightly problematic ex-educational mill that had already been converted for Mach3 for £650.
Replacing the DC motor & drive with a 3phase motor and drive plus some limit switches brought it up to £900, add a license for Mach3 and 4-Axis Standard BobCad/Cam V25 and it runs over your budget by a few hundred, but for what you want to do I'm sure there's some free or very cheap 2/2.5D Cad/Cam that would leave you space in your budget for a nice fly press - my No.3 cost me £80 from a local engineering tool dealer - he had around 20 in stock and I waved pound notes under his nose ;-) .
ATB,
NickLast edited by magicniner; 24-11-2013 at 12:46 PM.
RFQ: Simple job cutting simple shapes out of camera lens cap
By RockandGrohl in forum Projects, Jobs & RequestsReplies: 15Last Post: 20-04-2013, 01:23 AM -
Cutting wooden letters and shapes - purchase help for a newbie please!
By kemo_2002 in forum Marketplace DiscussionReplies: 18Last Post: 29-08-2012, 11:40 PM -
Metal Spinner
By vueselection in forum Opportunities Available & SoughtReplies: 0Last Post: 28-05-2012, 03:30 PM -
FOR SALE: Grinding wheels for sale. various colours,sizes, shapes and grits.
By swarf-boy in forum Items For SaleReplies: 3Last Post: 05-11-2011, 06:07 PM -
Machining odd shapes on a denford starmill
By Kai in forum Denford MillsReplies: 19Last Post: 02-12-2010, 06:52 PM
