Thread: Cutting metal shapes
25-11-2013 #11
Something like this maybe: https://www.stepcraft-systems.com/
25-11-2013 #12
25-11-2013 #13
Judging by the photos on this page, the machine uses simple brass rollers on a (possibly?) aluminium extrusion to guide the X-axis. Although it looks like the rigidity of that system is adequate for engraving, I'd be concerned about the longevity.
The German word for 'ballscrew' is 'kugelrollspindel', but they've instead used 'Rundgewindespindel's, which are leadscrews. This means the machine is likely to have higher backlash, especially once the leadscrew nuts have worn a bit. This is confirmed by the 'Wiederholungsgenauigkeit' (positioning repetability) being +-0.05mm. That's enough to show up on a detailed engraving.
Interestingly they have given some measure of stiffness. Although it says torsional, the units imply linear stiffness hence I think they are saying that the machine will deflect by between 0.1mm and 0.14mm if a force of 20N is applied, so the stiffness is between 143N/mm 200N/mm. Unimpressive, though might be adequate as your requirements are small. The thing to do would be to ask someone who'se got one of the cheap machines from eBay (e.g. CNC6040, CNC3020) to measure its stiffness, then we can make an objective comparison.Last edited by Jonathan; 25-11-2013 at 03:09 PM.
25-11-2013 #14
25-11-2013 #15
thanks :) will go for a look!
26-11-2013 #16
I think you'll find it's been sold.
26-11-2013 #17
Yep.... Sold now
26-11-2013 #18
wondering will it just be easier to get the mrs a scroll saw, something like a hegner se with variable speed. then she can cut custom shapes from soft 1050grade aluminium with that. i tried on the aluminium myself with a jigsaw and metal blade, it cut fine so a scroll saw with metal blade should be good.... all be it slow but maybe ok for custom one off stuff.
From what i can see on videos on the net a cnc router would make a mess of soft aluminium.
26-11-2013 #19
does anyone have a small chinese style router i could send a small bit of aluminium sheet to to see if it cuts a shape ok?
i just don't want to spend a heap of money on one if it doesn't work! :)
26-11-2013 #20
What happened, did the Mrs have other ideas ?
There are currently 28 users browsing this thread. (0 members and 28 guests)
RFQ: Simple job cutting simple shapes out of camera lens cap
By RockandGrohl in forum Projects, Jobs & RequestsReplies: 15Last Post: 20-04-2013, 01:23 AM -
Cutting wooden letters and shapes - purchase help for a newbie please!
By kemo_2002 in forum Marketplace DiscussionReplies: 18Last Post: 29-08-2012, 11:40 PM -
Metal Spinner
By vueselection in forum Opportunities Available & SoughtReplies: 0Last Post: 28-05-2012, 03:30 PM -
FOR SALE: Grinding wheels for sale. various colours,sizes, shapes and grits.
By swarf-boy in forum Items For SaleReplies: 3Last Post: 05-11-2011, 06:07 PM -
Machining odd shapes on a denford starmill
By Kai in forum Denford MillsReplies: 19Last Post: 02-12-2010, 06:52 PM
