    E-Stop are EMERGENCY stops, so should be wired for YOUR protection. When you've got your hand wrapped around a cutter, you won't have time to ponder on which E-Stop to press...
    The "usual" way to setup E-Stops is using a 24VDC circuit with all E-Stops in series which then drop out a contactor (or proper safety relay if you have plenty of cash!). You latch the contactor via a reset button and N.O. auxiliary contact on the relay. This way, the circuit will be safe if any E-Stop is activated or a cable gets broken. I've put my axis limits in series with the E-Stops because a near-crash IS an emergency. As for your feedback, you simply use another spare aux contact on the relay to make or break the BOB com/5v link.
  1. EMC2 home/limit switches... only acting as limit?
    By vputz in forum LinuxCNC (EMC)
    Last Post: 15-10-2014, 09:51 AM
  2. Another Home - Limit switch question
    By Cube3 in forum General Electronics
    Last Post: 26-12-2013, 07:51 PM
  3. FOR SALE: Z axis with Home/limit switch and Nema 23 3nm
    By Shinobiwan in forum Items For Sale
    Last Post: 02-02-2013, 10:54 AM
  4. Limit switch Cable ...
    Last Post: 17-01-2011, 04:37 PM
  5. Limit switch's - best configuration?
    By HiltonSteve in forum General Electronics
    Last Post: 13-08-2009, 01:26 PM
