Thread: New spindle needing new mounts
What your wanting to do is called tramming the spindle and using a Set square with Steel in Collet is not good enough and won't be accurate.
Easy way is to get a Piece of round steel bent 90deg that fits in the spindle, make sure it's stiff and ridged so doesn't flex. Make it has wide has your Bed then mount a dial gauge on the end. Then sweep around 180 deg and see how much it changes, if your spindle is trammed correctly it should hardly move in each Axis direction.
The wider the sweep the more accurate it will be.
RFQ: Ballnut Mounts needed.
By dudz in forum Projects, Jobs & RequestsReplies: 1Last Post: 05-03-2014, 09:01 AM -
Needing advice on linear rail blocks
By oldmam4m80s in forum Rails, Guideways & BearingsReplies: 0Last Post: 27-10-2013, 07:57 AM -
RFQ: Nema 23 motor mounts
By luke11cnc in forum Projects, Jobs & RequestsReplies: 14Last Post: 06-10-2011, 02:21 PM -
Mounts; Motors, bearings etc..
By mocha in forum Gantry/Router Machines & BuildingReplies: 19Last Post: 29-09-2011, 10:20 AM -
FOR SALE: MDF NEMA 23 Motor mounts
By Tom in forum Items For SaleReplies: 40Last Post: 21-08-2010, 01:23 AM
