    dsc's Avatar
    Lives in Lincoln, United Kingdom. Last Activity: 17-06-2020 Has been a member for 9-10 years. Has a total post count of 252. Received thanks 1 times, giving thanks to others 11 times.
    I'm using two small locknuts on a miniature ballscrew (R1202) and I cannot seem to find a suitable c-hook wrench or some other tool which would allow to tighten two M10 x 0.75 locknuts to hold the ballscrew end in a bearing.
    Has anyone seen anything like this somewhere? or do I need to make my own?
    Regards,
    dsc.
    Hi DSC
    can i assume you are looking for a thin (plate) spanner?
    If so try a search for Park Tools (cycling gear) thin open ended spanners are required for adjusting the wheel bearings on bikes, can't remember off hand what size mine are but think there 14mm.
    Regards
    Mike
    dsc's Avatar
    Hi Mike,
    I remember seeing a set of those on my dads bike when I was a kid, didn't know what they were back then, but indeed it looks like they might work. I'll try and get a single small one to try it out.
    Cheers,
    dsc.
    Lives in East Lothian, United Kingdom. Last Activity: 1 Hour Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,989. Received thanks 373 times, giving thanks to others 9 times.
    If it is thin spanners, then in the bike trade they're classed as cone spanners.
    However, going by the original post, I would of guessed it's a hook spanner you're after?
    dsc's Avatar
    This spanner would do as well, there's not much tightening to do, a hook spanner would be better, but due to the way the locknut is recessed in the housing, the ideal thing would be a locknut socket, but those are stupidly expensive.
    Regards,
    dsc.
  1. RFQ: Small sized Parts need making, small batches
    By Ptee in forum Projects, Jobs & Requests
    Last Post: 17-01-2014, 06:07 PM
  2. torques - rough estimates for wrench ranges
    By dsc in forum Machine Discussion
    Last Post: 04-01-2013, 01:19 AM
  3. What tool would you use for this?
    By Kai in forum Tool & Tooling Technology
    Last Post: 21-03-2011, 06:08 PM
  4. RFQ: Maybe another small(ish) job for someone...
    By D-man in forum Projects, Jobs & Requests
    Last Post: 05-07-2010, 11:47 AM
